Rear brake hoses
- 02V70
- Year and Model: 2002 V70XC
- Has thanked: 53 times
- Been thanked: 40 times
I’m having trouble removing the rear brake hoses partly because the flare wrench kit from harbor freight had both sides of the labeled 13/14 wrench be actually 14mm. The rear hose looks like this with the fronts being worse. If I can’t get it out, can I just leave it for the next 5+ years? Here is what it looks like. Note the two cracks.
Also one of the replacement rear brake hoses (both the same brand) doesn’t have that weight thing. Is this fine?
2002 v70 X/C 288k miles
- Blacklab467
- Year and Model: 2007 xc 70
- Has thanked: 117 times
- Been thanked: 271 times
Those are a pain in the ass, you have to soak them for a couple weeks in penetrating fluid, and you don’t want to strip them or damage the hard line. I find that the flare wrenches are useless unless they’re Snap on or Mac Tools. For some reason they always wreck the nut before loosening it.
2003 XC 70 (sold)
- Has thanked: 987 times
- Been thanked: 1075 times
On a hose you will be replacing, you can cut the old hose short and use a deep, 6 point socket to loosen the hose end.
Any other time use only the BEST flare wrenches if you suspect rust. Good flare wrenches are wide and have heavy reinforcement on the sides.
- MoVolvos
- Has thanked: 312 times
- Been thanked: 525 times
.volvolugnut wrote: 27 Mar 2024, 19:31 On a hose you will be replacing, you can cut the old hose short and use a deep, 6 point socket to loosen the hose end.
I was going to say I think Eric The Car did the same thing in one of his videos
- BlackBart
- Has thanked: 967 times
- Been thanked: 921 times
I think that black ring is probably hard rubber where the hose would rub against a suspension piece.
Good job getting them off.
- 43 Replies
- 9853 Views
- 793 Views
Last post by JRev
- 1051 Views
Last post by bmdubya1198
- 1115 Views
Last post by cn90
- 13 Replies
- 3946 Views
Last post by volvolugnut
