03' V70 Alarm Module woes, advice needed
850 LPT
Year and Model: 96' 850
Has thanked: 331 times
Been thanked: 242 times
Post by 850 LPT »
I knew when my daughter bought the car in December that the alarm module was bad. That wasn't a big deal, I replaced it with a new one from FCP in January.
That didn't fix the problem though, the error message on the dash came on at first start up. I thought maybe it's a residual code and I had to clear it with VIDA, but that did nothing. My conclusion was that the new module was bad right out of the box, and so this weekend I replaced it with another one. Same story, the "alarm system service required" message came right back.
I am thinking that the parts from FCP are all old stock and the batteries went bad just sitting on the shelf. But am I missing something here? Or is it really just bad luck.
I will email FCP and see what their word of wisdom might be. But they probably have no way of knowing how old the parts are that they sell.
For now, I am thinking of just pulling the fuse until I can figure this out. I saw elsewhere online that this is possible, and other than the message coming back all the time, there should be no other problems. Is that true?
What do you experts think?
Thanks, Dirk
58' Porsche Diesel Junior
13' Honda Odyssey :oops:
Has thanked: 1506 times
Been thanked: 3818 times
Look at the build code on the alarm module. Snap pic so we can figure burnout.
Let’s get that 99 going too. Sorry I’ve been offline so much
Has thanked: 1850 times
Been thanked: 1712 times
Often the plastic casings have a mold mark on them with dates when the plastic was molded. That may give you an idea of the age of the part.
Are you sure the alarm module is the issue? It causes lots of other issues with thinks like the sunroof when it goes bad, so perhaps it is something else on the system that is bad and not the module itself.
850 LPT
Post by 850 LPT »
abscate wrote: 01 Apr 2024, 12:09 Look at the build code on the alarm module. Snap pic so we can figure burnout.
Thanks Steve, where do I find the build code? I wish I had known this, because now it's all buttoned up and the car is going back to Boston on Friday. I pulled the fuse for the module so my daughter doesn't have to deal with random alarms going off. The car is parked right next to someones bedroom window the next street over. Pulling the fuse seems to have no ill side effects, I am driving it today and everything is behaving normal.
I also emailed FCP and I'm waiting to hear what their suggestions are.
I would love to get Matilda going again, the old gas in the tank is making me nervous. Lets be in touch about it. This year has been crazy so far with so many other projects going on.
Dirk
850 LPT
Post by 850 LPT »
scot850 wrote: 01 Apr 2024, 15:20 Often the plastic casings have a mold mark on them with dates when the plastic was molded. That may give you an idea of the age of the part.
Hi Neil, thank you. I still have the first one that I replaced, so I can check the plastic housing on that. Good idea.
I was also wondering if there might be something else going on. I went in with VIDA to take a look, but I cannot tell if some of those codes could be interrelated. They seem trivial to me, but I'm no expert. I have heard about the sunroof issue, but that is working normally, as well as everything else in the car.
I'm no expert on electrics as you probably well know! However looking at the codes I don't think any of the other 5 have a connection to your issue or than the alarm communication fault.
Seat heater , mirror x 3 and IAQS fault seem to be unrelated.
xanthefin
Year and Model: 1997 850
Has thanked: 106 times
Been thanked: 130 times
Post by xanthefin »
Siren communication fault is why you get that Alarm com fault on DIM.
Its fault symptoms includes "Alarm does not work".
Alarm consist of multiple modules on P2 to create "Alarm System":
CEM, UEM, CCM, DDM, PDM, MMS, DIM, ISM, REM, Siren module and multiple Volvo Guard™ stickers at windows and switches here and there and or wires at windows.
Which ever your car is equipded with. not all have all.
scot850 did throw correct with being "mirror" for that.
If i would be i would focus at UEM module specially connection with its connection to Siren Module (16/35) (com is via Volcano Lite serial not CAN Bus).
Plus because VIDA is so lovely design.. Select "Delivery" tab not "initial State" if you used more than one time Vida on same car as you looking at history many cases.
Footnote before others comes say front of my face again.
Wait third independed party to confirm anything what i say. Trust only Americans®.
br0dy519
Year and Model: 2004 XC70
Has thanked: 126 times
Been thanked: 116 times
Post by br0dy519 »
Does the UEM live inside the rear view mirror? I wonder because I had a leak in my windshield and has some gremlins for a while..
04s60 2.4
04xc70 2.5t
xanthefin
Post by xanthefin »
br0dy519 wrote: 04 Apr 2024, 12:03 Does the UEM live inside the rear view mirror? I wonder because I had a leak in my windshield and has some gremlins for a while..
Its literally attached behind the mirror you staring in fear or in awe.
Edit here with picture.
See if you can load module ID info in VIDA, it might give the date code , too.
