98 s70glt More alarm woes
deeplipceo
Year and Model: 98 s70 glt
Post by deeplipceo »
Good morning,
I have tried my best to not have to post this question,but after searching for the last week nothing has worked. So here is the situation. I went down to my car to go to work, and my drivers door was frozen shut so I opened the passenger door and the alarm triggered. Obviously at this point the car will no longer start. I bought the car without a fob so that option is a no go. I tried turning the key in the drivers lock and its stuck so thats a no go. I then tried using the unlock button in the car nothing worked no power to the switch, so thats a no go. I tried grounding(double pulse) the red/gray wire that goes to the denso alarm again wouldnt disarm or unlock. I have checked every fuse nothing is bad. I read you can bridge pin B21 to a power to atleast start the car, but where is that pin located? I am at a loss any imput would be awesome
deeplipceo
Figured it out replaced alarm unit, and good to go. Mods please delete
