98 S70 -- fan on when parked?
mar601
- Year and Model: 1998
- Has thanked: 34 times
- Been thanked: 5 times
I just got my car out of the shop (2nd time) and originally was having the upper radiator hose blow off. They replaced the radiator because there's a flange that had eroded. But I'm taking it back because I still don't hear the fan kicking on. They replaced the thermostat and ect sensor and I know the fan works and has new relay module. My question is -- I had also wanted them to look at why the fan doesn't turn on (like it originally did years ago). when the engine is hot and the car is parked. I just did some driving and after parking the thermostat housing read 221F -- yet hadn't heard the fan on my trip or parked. SHOULD the fan come on when parked? What is the issue if it doesn't? -- thanks
- Has thanked: 1850 times
- Been thanked: 1712 times
Did you have any software updates over the years? Maybe the feature was turned off.
Does your external temp sensor for the engine work? I think the 98 has 2 front temp sensors. One for the cabin temp readout and second one for the engine. That one is tucked up under the front on the LHS of the grill (standing in front of the car) or attached to the air guide under the car.
mar601
Thanks Neil. I didn't realize there were sensors up front. Nope -- no software update I'm aware of. THANKS. I'll look for that engine temp sensor and just go ahead and replace it if it isn't a bear.
jmartin919
- Year and Model: S70 GLT SE 2000
- Has thanked: 94 times
- Been thanked: 39 times
If you have two sensors just swap them. Very easy to do.
'00 S70 GLT SE
'82 MB 380SL
'11 MB E350 Sport
'84 Chevy C10
'93 850 GLT NA SOLD
'82 MB 380SL
'11 MB E350 Sport
'84 Chevy C10
'93 850 GLT NA SOLD
Thanks for clarifying. I was not clear earlier that there are 2 sensors like you mention. They are the same. The other one is for the dash readout and they are the same sensors.
- Clemens
- Has thanked: 473 times
- Been thanked: 219 times
I came across something interesting in an originL Volvo service manual the other day:
The fan may come on any time, includi g 10 minutes after shutting the engine off.
My 94 T5 and my 95 10V does/did it occasionally after shutting off the engine, my 96 R never does that.
Summer: 1996 855 R
Winter: 1994 855 T5M
Donor: 1995 854 10V
Donor: 1995 854 10V
- MoVolvos
- Has thanked: 310 times
- Been thanked: 524 times
00 S70 SE N/A doesn't but 02 V70 XC does. Hit and miss.
