1998 Volvo V70
Performing a smoke test
After fixing a couple broken hoses by fuel pump this is the next place smoke comes out.
Should it?
Should there be a cap on this or a hose attached?
EVAP canister - should it be smoking? - should this be capped? SOLVED Topic is solved
Andrew Vanis
- Year and Model: 1999
- Been thanked: 11 times
1998 V70 NA (11/97 build date) 230,000mi
- Has thanked: 1848 times
- Been thanked: 1710 times
Simple answer is yes it should. That open pipe should connect to the evap valve under the rear of the fender:
https://www.volvocarstorontoparts.ca/a/ ... 74761.html
Andrew Vanis
Thanksscot850 wrote: ↑13 Jul 2024, 07:25 Simple answer is yes it should. That open pipe should connect to the evap valve under the rear of the fender:
1) For EVAP testing I plugged it and now smoke moved to the top of tank so that's the next adventure
2) Thanks for your heads up. After thinking I had nothing there, I looked deeper and found the hose, cracked. This post was also helpful https://volvo850wagon.wordpress.com/201 ... eak-p0455/
There is nothing in that vicinity or at the back of my fender.
this post has a similar diagram to the one you linked and it shows an alternate U hose (#16) that doesn't attach to anything and in the diagram you liked it is the hose #20 that attaches to #18 Vapor Canister Purge Solenoid
viewtopic.php?p=162056#p162056
jmartin919
- Year and Model: S70 GLT SE 2000
- Has thanked: 94 times
- Been thanked: 39 times
If #16 is part 9443308, that failed on my 2000 S70 at the connection and I was getting an EVAP code. I just sealed the crack with RTV.
'00 S70 GLT SE
'82 MB 380SL
'11 MB E350 Sport
'84 Chevy C10
'93 850 GLT NA SOLD
'82 MB 380SL
'11 MB E350 Sport
'84 Chevy C10
'93 850 GLT NA SOLD
Andrew Vanis
Wrapping this topic up
So my hose was short and cracked at the end. I cut back to good hose. Then I cut off a couple inches to attach to the canister and I spliced in a hard or plastic tube as an extension. So far so good.
Also learned about the valve at the end of this hose and researching on here that it's normal for it to be open to the atmosphere. So for evap smoke and pressure testing I plugged the exit from the canister and it held up to 5 PSI no issue
Thanks for the help
Thanks for the help
Well done! Glad it worked out well!
- 914 Views
Last post by packetfire
- 935 Views
Last post by bil745t
