80mph is technically illegal, however the indicated 78mph on my speedo which could legally be over-reading by up to 10% + the 2mph allowance most police forces comply with (70+10%+2=79) would not be an issue, therefore the chance of being ticketed for 78 on my speedo whilst keeping up with the rest of the traffic is highly unlikely.
- P80GLT
- Has thanked: 154 times
- Been thanked: 176 times
- Has thanked: 1497 times
- Been thanked: 3810 times
My gasket was for a HPT so maybe there is a difference between HPT and LPT?Chuck W wrote: ↑11 Aug 2024, 16:56Late to the chat, but there *is* a gasket available for the angle-flange turbos (maybe even the straight flange ones too).scot850 wrote: ↑10 Aug 2024, 12:39 I have had a look at the parts drawings again at higher magnification, and it now looks clear as hausmeister and Bdub have clarified, there is no gasket between the turbo and the downpipe to the cat. It looks more like a cup and seat type seal. If you had issues with worn or pitted surfaces, a little gasket sealer should fix that.
Thanks to you guys for helping clear that up!
I have one on both of our cars (16T angle flanges to 3" DP).
Was there one from the factory? I dunno. These cars are WAY past that point.
jsrnsis
- Year and Model: P80 enjoyer
- Has thanked: 25 times
- Been thanked: 68 times
looking into it, for some reason that part number gasket is marked as being for the diesel cars. Not sure if they have different downpipe flanges, or if the fuel type exception is even true. I don't even know if my exhaust is leaking there, but I don't know why there would be residue around the flange.
I used an engine support brace instead of jacking up by the crank engine mount, so once I get a day where I'm not exhausted after work I'm going to swap out the engine mounts. I haven't had any luck on this car with aftermarket crank-side mounts but I have an annoying vibration while driving that is felt through the steering wheel. Also seems to be a slow vibration at idle. But I was sanding and painting some rear suspension parts and saw the rear anti-sway bar end links were looking pretty shot. All cracked and stretched looking.hausmeister wrote: ↑10 Aug 2024, 08:38 Meh I should also drop the pan... is it possible to sneak in new rod bearings at the same time? I have seen people on yt do this on other cars just with the pan removed.
Anything else that you should do at the same time? engine mounts maybe?
1998 V70XC black 183xxx
2014 S80 T6 AWD 110xxx
1998 V70XC nautic blue 155xxx
1997 850 GLT 123xxx
2024 Honda CRF110F
Previous Volvos:
1997 850 GLT 239,577
1998 V70 NA silver 202,510
1994 850 NA gray 125,000
1998 V70 NA white 163xxx
1997 850 GLT 123xxx
2024 Honda CRF110F
Previous Volvos:
- Chuck W
- Year and Model: 97 854 T5
- Has thanked: 96 times
- Been thanked: 333 times
Perhaps.
I can't say as my car is an HPT, hers is an LPT and both have angle-flanged 16Ts going to 3" downpipes, so...
(Again, not factory builds).
If you have a minor leak at the turbo outlet to the exhaust, the gasket wouldn't hurt things. They're single-use, as they do crush/deform on installation.
- Has thanked: 304 times
- Been thanked: 517 times
The exhaust housing is the same between HPT and LPT. Only difference comes in later '00 or 2001 when they went to a 7cm3 exhaust volume vs. 6cm3 on the earlier turbos.
Can’t see a gasket in this thread , maybe I made that up??abscate wrote: ↑12 Aug 2024, 04:00My gasket was for a HPT so maybe there is a difference between HPT and LPT?Chuck W wrote: ↑11 Aug 2024, 16:56Late to the chat, but there *is* a gasket available for the angle-flange turbos (maybe even the straight flange ones too).scot850 wrote: ↑10 Aug 2024, 12:39 I have had a look at the parts drawings again at higher magnification, and it now looks clear as hausmeister and Bdub have clarified, there is no gasket between the turbo and the downpipe to the cat. It looks more like a cup and seat type seal. If you had issues with worn or pitted surfaces, a little gasket sealer should fix that.
viewtopic.php?t=96254&hilit=Resurrectio ... h&start=40
- Chuck W
I didn't say that you weren't telling the truth in regards to a factory installation.abscate wrote: ↑13 Aug 2024, 02:13
It was more of a "needed/not needed?" thing. It more depends on the situation/condition of the mating parts, and not how spicy the turbo is.
- Volvebaker
- Year and Model: 1993 850 GLT
- Been thanked: 10 times
what did I do today? well, I rolled her over 250k
- ZionXIX
- Has thanked: 64 times
- Been thanked: 194 times
Well done Sir!Volvebaker wrote: ↑13 Aug 2024, 19:51 what did I do today? well, I rolled her over 250k
IMG_0906.MP4
- Has thanked: 2650 times
- Been thanked: 1240 times
I'm just in this thread right now to report that this thing has 1,083,726 views. What!
