Dear All,
I kindly ask for advice on where to look for the issue.
Vehicle: V70 2.5 TDI (1999)
The air conditioning system recently underwent a major service (new compressor, dryer, radiator + flushing/new refrigerant). Everything was working fine.
The car sat idle for a while, and the battery died. I started it with a booster, and it worked.
After about 30 minutes of driving, the air conditioning stopped working. The compressor isn't engaging. The internal circulation and OFF buttons on the control panel are blinking.
The FCR shows the following errors: ECC-413, ECC-414.
I’ve checked the sensors in the system (2-pin and 3-pin), swapped them from another car – same result.
I removed and cleaned the interior temperature sensor (it spins after starting the engine and air conditioning).
Any ideas on what I could check next?
[V70, 1999, 2.5 TDI] Air Conditioning - Compressor does not run
- MichaelPL
- Year and Model: S70, V70
- Has thanked: 2 times
Volvo S70 SE 1998 2.5 20V 170 KM Aqua Blue Metallic
Volvo S70 1997 2.5T 193 KM Mystic Silver Metallic
Volvo V70 1999 2.5 TDI 140 KM Graphite gray metallic
FSC Żuk 1990 2.4D
Polski Fiat 125p 1974
FSC Żuk 1990 2.4D
- Has thanked: 2199 times
I am not clear. Did you swap the cabin temp sensor? The fan may run, but the temperature portion may be bad. I have had to replace one for this. If it is not sensing temperature the system will not run.
- misha
- Has thanked: 155 times
- Been thanked: 432 times
'71 144 S
'73 144 De Luxe
'78 244 DL
'78 244 DL
'79 244 GLE
'85 340 GLS
'71 144 S
'73 144 De Luxe
'78 244 DL
'78 244 DL
'79 244 GLE
'85 340 GLS
- MichaelPL
I removed the sensor and cleaned it, but I haven’t replaced it with a new one. I’ll try today.scot850 wrote: 09 Sep 2024, 06:26 I am not clear. Did you swap the cabin temp sensor? The fan may run, but the temperature portion may be bad. I have had to replace one for this. If it is not sensing temperature the system will not run.
I assumed (perhaps incorrectly) that since the fan is running, it’s working.
FSC Żuk 1990 2.4D
FSC Żuk 1990 2.4D
Unfortunately not a guarantee. The little red bulb at the front is the thermostat. The fan pulls the cabin air over that for it to determine the cabin temperature.
Careful when removing the unit If you have already seen it there is a rubber casket the fits into the front of the sensor. It often gets stuck behind the dash or falls down inside the center console area. It helps seal the area so the fan air draw is more effective.
Good Luck!
Good Luck!
- MichaelPL
Hi Neil,scot850 wrote: 09 Sep 2024, 10:21 Unfortunately not a guarantee. The little red bulb at the front is the thermostat. The fan pulls the cabin air over that for it to determine the cabin temperature.
Good Luck!
I’ve removed the cabin temperature sensor and replaced it with a working one (I’m certain it’s fully functional as it came from another car). I’ve also swapped out the entire air conditioning control panel with a different one. Unfortunately, the result is still the same – the AC compressor isn’t engaging.
Any other ideas on what could be the issue?
Thanks again for your help!
Michael
FSC Żuk 1990 2.4D
FSC Żuk 1990 2.4D
- misha
Probably leaked out from evaporator.
Remove a connector close to a firewall and jump the pins on the connector side while engine is running... blower and ac turned on.
Jump only for a few seconds.
If clutch engages that way...the system is empty.
'71 144 S
'73 144 De Luxe
'78 244 DL
'78 244 DL
'79 244 GLE
'85 340 GLS
'71 144 S
'73 144 De Luxe
'78 244 DL
'78 244 DL
'79 244 GLE
'85 340 GLS
- MichaelPL
It is brand new as well as compressor
FSC Żuk 1990 2.4D
FSC Żuk 1990 2.4D
- misha
You didn't mentioned that evaporator was replaced in 1st post...only compressor,dryer and radiator(condenser).
'71 144 S
'73 144 De Luxe
'78 244 DL
'78 244 DL
'79 244 GLE
'85 340 GLS
'71 144 S
'73 144 De Luxe
'78 244 DL
'78 244 DL
'79 244 GLE
'85 340 GLS
- MichaelPL
My mistake Misha. The evaporator remained the same, but it was flushed with air conditioning cleaner until clean.misha wrote: 09 Sep 2024, 13:25 You didn't mentioned that evaporator was replaced in 1st post...only compressor,dryer and radiator(condenser).
Are you referring to jump in the air conditioning relay socket - black-purple ? (red circle)
- VolvoFuelSystem05.JPG (20.08 KiB) Viewed 439 times
FSC Żuk 1990 2.4D
FSC Żuk 1990 2.4D
