2010 XC90 Rear wheel jumping/banging when turning in lock
skheng2656
Year and Model: XC 90 2010
Has thanked: 2 times
Post by skheng2656 »
Hi all,
I have a 2010 XC90, not had to car long so could be an underlying issue but ive noticed when turning in lock in either forward or reverse, left or right, i bangs/jumps on the back left wheel.
Just had new wheel bearings Disks, shoes and pads. Ive also not set the handbrake shoes up yet so they shouldn't be causing any interference.
Could the rear toe be out enough to cause this issue? its just had a couple of tyres as the old ones were scrubbed off on the edges.
any help/advice mush appreciated thanks!!
matthew1
Site Admin
Year and Model: 850 T5, 1997
Has thanked: 2864 times
Been thanked: 1332 times
Post by matthew1 »
Can you shoot a video of this and put it up somewhere like YouTube or a video share website? Preferably shot by a second person who is filming close to the wheel.
Also -> Amazon link
MoVolvos
Has thanked: 312 times
Been thanked: 525 times
Post by MoVolvos »
Wonder if the rear brake shoe is binding due to parking brake cable?
Year and Model: 2001 V70
Has thanked: 987 times
Been thanked: 1078 times
Post by volvolugnut »
If your old rear tyres were badly worn on the edges it may indicate bad rear suspension parts. Jack up the rear on each side and check if you can move the wheel in any direction. You might find very loose parts that cause your problem.
skheng2656
Hi all thanks for the reply’s,
I ment to add I have just replaced some of the suspension bushings as they looked abit sketchy.
So the car will be to track up and also the tyres are winters now.
I will try get a video of it, to be honest I’ve not watched it my self to see what it’s doing as there was no one about.
Again thank you for the responses
The park brake pads shouldn’t be causing an issue but I’ll adjust it all up just to rule that out
skheng2656
matthew1 wrote: 29 Sep 2024, 14:10 Can you shoot a video of this and put it up somewhere like YouTube or a video share website? Preferably shot by a second person who is filming close to the wheel.
No video but what I have found out is that it’s stuck in 4wd until I pull the fuse and you can feel it drop out. It then drives fine.
Halsey had just had a service and I’ve swapped the control solenoid with another one I had .
Krons
Has thanked: 198 times
Been thanked: 215 times
Post by Krons »
Any codes? I believe the all-wheel-drive system engages when wheel speeds are off front to back a wheel speed sensor issue normally will trigger an ABS code. Are the tire sizes the same front to back?
Pulling the fuse would seem to indicate that the mechanical side is OK.
08 C702.5T (sold)
The non-Swedes:
skheng2656
Krons wrote: 02 Oct 2024, 04:53 Any codes? I believe the all-wheel-drive system engages when wheel speeds are off front to back a wheel speed sensor issue normally will trigger an ABS code. Are the tire sizes the same front to back?
Hi thanks for the reply
Yes tyres are same size, just all seasons on the back and normals on the front
Rear has had new wheel bearings and abs sensors
I had the wheel speeds up on Vida on a test drive and they all read the same.
Thanks
