NC855R
Year and Model: 1997 850 R
Has thanked: 45 times
Been thanked: 28 times
Post by NC855R »
For today, the clutch, pressure plate and transmission are now installed! Cables in place and shifter installed.
Question about the clutch cables coming out of the firewall, do they pass to the left or right of the steering column as you are looking at the firewall?
bmdubya1198
Year and Model: 2K V70R M56
Has thanked: 304 times
Been thanked: 517 times
Post by bmdubya1198 »
NC855R wrote: 17 Nov 2024, 17:50 For today, the clutch, pressure plate and transmission are now installed! Cables in place and shifter installed.
Nicely done! I can't remember exactly, but you may be able to catch a glimpse of where the cables are routed in relation to the steering column in one of Robert's latest videos here
454cid
Year and Model: 1996 850
Has thanked: 145 times
Been thanked: 129 times
Post by 454cid »
scot850 wrote: 16 Nov 2024, 17:14 3) The bush removal. Now this is where the fun started. Tool attacked, but when torqued the bad design has the slider block sitting on the bush metal sleeve. This forces the tool downwards and bends the pins. To prevent that, out came the 30" long pipe pliers (in the UK we called then Stilsons), but these were my grandfathers which he bought in the 1960's in Denmark. You can clamp these with a pull lever and this locked the Volvo tool to the bush. After a lot of pulling and a little chisel action the bush came out.
When I Google "stilsons" I get normal looking pipe wrenches. Is that what you mean, or something else?
Here's an example https://www.amazon.com/Toolzone-SP068-S ... B001O5M1ZC
1996 850
2010 Ford Focus SE
2006 Cadillac CTS
1996 Mercedes C220
1999 Chevrolet K3500
1969 Buick LeSabre Custom 400
Has thanked: 1847 times
Been thanked: 1710 times
Something else. It does the same job but a Scandinavian variant (Probably Swedish!). I'll try to remember to take a picture tomorrow and post back here.
DennisCA
Been thanked: 59 times
Post by DennisCA »
I'm doing a mod to my 850, installing a secondary washer pump in series with the original. I've done it to other cars and really think it improves the washers. I am dependant on good washers this time of year. While I was working on where to put the pump (found a nice spot behind the front right headlight):
I noticed that a line that was not connected. I reconnected it but I cannot tell what it does. It's the 3rd line with the small hose clamp next to the other two lines that are not supposed to be hooked up to anything.
Anyone know what it does?
454cid
Post by 454cid »
DennisCA wrote: 18 Nov 2024, 03:37 I'm doing a mod to my 850, installing a secondary washer pump in series with the original. I've done it to other cars and really think it improves the washers. I am dependant on good washers this time of year. While I was working on where to put the pump (found a nice spot behind the front right headlight):
I'm looking forward to hearing more. The washers on my 850 could use a lot of improvement. I keep intending to go through the system, but never seem to make it a priority. The system on my S70 was fantastic. It's not just a matter of nozzles.
I think one hose is a vent, so the bottle doesn't collapse.
What I really do need to do soon is pump out the existing fluid, and replace it with something that won't freeze. I need to come up with some sort of pump to do so.
1996 850
2010 Ford Focus SE
2006 Cadillac CTS
1996 Mercedes C220
Fit P2 washer nozzles for the windshield. They give a much better spray coverage than P80 ones.
Wagons have 2 vents. One for front pump and one for rear.
With regard to the 'Stilson' question. Here are pictures of the Swedish (better) equivalent:
Swedish Stilson or pipe wrench
Bahco brand is the best
While I own what is considered the 'Stilson' style pipe wrench, I always preferred these as they are just easier to work with and adjust. You can also clamp down with the jaws like on pipe pliers. These are at lease 60-70 years old and still work as designed!
bmdubya1198
Those Swedish pipe wrenches are a life saver. Harbor Freight carries them in their Icon brand now, and while they're okay, the fast adjustment button SUCKS. Lets them slip way too easily. Bahco is top tier for those.
BlackBart
Has thanked: 927 times
Been thanked: 884 times
Post by BlackBart »
Holy mackerel, that is a wrench!
