Vida CEM swapping
dikidera
Year and Model: S60 2005
Has thanked: 68 times
Been thanked: 187 times
Post by dikidera »
vtl wrote: 17 Nov 2024, 14:20
dikidera wrote: 17 Nov 2024, 12:37 @vtl
If we need a Teensy with fast clocks to detect CAN line jitter and side channel brute force the pin for CEM. How can VDASH do the same with a simple Mongoose JLR?
MY2006+ supports UDS.
So my P2 MY2005 (facelift) is excluded?
vtl
Year and Model: 2005 XC70
Has thanked: 130 times
Been thanked: 686 times
Post by vtl »
dikidera wrote: 17 Nov 2024, 15:48 So my P2 MY2005 (facelift) is excluded?
My P2 MY2005 as well ;)
Treur
Year and Model: 2007 V70
Has thanked: 3 times
Been thanked: 7 times
Post by Treur »
Dudde wrote: 16 Nov 2024, 11:47
Treur wrote: 16 Nov 2024, 09:28 Hi friends. Can anyone help with SBL files for P2 and P3 platforms. I need for CEM, BCM P2 and all for P3. If anyone can help, I promise not to distribute.
For what do you need them if you mind me asking?
To read and write modules.
Treur
Post by Treur »
5 bytes via UDS?))) tryied, 1pin/s, can’t faster (dice, skanmatic, Mongoose)
V70user
Year and Model: 2003 V70 2.3T5
Been thanked: 3 times
Post by V70user »
According to a post below
viewtopic.php?p=609357#p609357
I can confirm that T5Luke's method works. Tested with Arduino Uno and Nano. Both read CEM flash without errors. Because CEM cracker still doesn't crack Brick CEMs so...
I tried it on three brick shape CEMs:
1- CEM 8645171 - 2000MY 07week
2- CEM 8645171 - 2000MY 11week
3- CEM 8688434 - 2002MY 36week
I used 12v from power supply. 12V connected to CEM pins as showed at picture and as an external power to Arduino. Ground from CEM and Arduino connected together.
In cases 1 and 2 You have to connect 5 wires. I used a sharp probing needles and scratched delicately connecting points on CEM's pcb
The whole readout takes 6 minutes. After this You can copy the entire readout and using for example HxD program create a new file with .bin extension and paste this readout.
Both CEMs 1 & 2 have PIN at 0x4000 therefore if You are going to use CEMTool , You have to copy this PIN and for CEMTool needs
paste it at 0x6000, otherwise CEMTool will show wrong PIN, because program search PIN at 0x6000.
In case 3 You have to connect only 4 wires (without RESET), otherwise the flash memory won't be read. Maybe it is only at that CEM, but it was read this way.
In this CEM (2002MY 36week) PIN is placed at 0x6000 so there is no need to changing anything
And a cherry at the top of the cake
Changes were made and have been successfully written back to CEM's flash memory.
Thank You all guys, and special thanks to T5Luke for his effort put in this project
shxc
Year and Model: 2007 XC70 D5244T4
Has thanked: 2 times
Post by shxc »
Has anyone successfully made changes to CEM (L-shaped) flash memory on a MY2007? Any help would be greatly appreciated!
Dudde
Year and Model: 2005 V70 and more
Has thanked: 16 times
Been thanked: 17 times
Post by Dudde »
shxc wrote: 20 Nov 2024, 11:09 Has anyone successfully made changes to CEM (L-shaped) flash memory on a MY2007? Any help would be greatly appreciated!
What do you need help with?
shxc
Post by shxc »
Dudde wrote: 20 Nov 2024, 13:36
Basically, I want to modify some configurations in the CEM, such as adding a sound amplifier. From what I understand, all information about configuration parameters should be available in the VIDA database.
Currently, I lack the knowledge of how to:
  1. Read the flash memory for that specific CEM.
  2. Correctly hex-edit the configuration (I’ve read that the configuration starts at the 8100 offset).
  3. Write the updated flash back to the CEM.
Thanks.
wxp73
Year and Model: V70 T5 2001
Post by wxp73 »
V70user wrote: 20 Nov 2024, 08:59 Both CEMs 1 & 2 have PIN at 0x4000
In my CEM at 0x4000 I have FFFFFFFFFFFF, so I need to copy that in 0x6000?
vtl
Post by vtl »
wxp73 wrote: 20 Nov 2024, 14:06
Brick CEM has pin either at offset 0x4000 or 0x6000. Yours is at 0x6000. Don't forget your dump can be byte swapped or not, depending on how your read it. Plus regular shuffle.
