Ticking Noise! Volvo 850! Help...
MoVolvos
Has thanked: 312 times
Been thanked: 525 times
Post by MoVolvos »
Since the Swepco 306 15W40 is expensive and not as suitable as 5W40 for your winters you can try the Swepco 502 Premium Engine Oil Improver in your 5W40 oil for the lifter noise. I do recommend Rotella T6 5W40 or the preferred Swepco 308 5W40 as diesel oils will clean better than standard synthetics.
https://www.pelicanparts.com/More_Info/ ... PEL-SWP502
https://stratson.eu/product/swepco-502- ... -improver/
https://www.paragon-products.com/Swepco ... /sw502.htm
https://lnengineering.com/swepco-502-pr ... ottle.html
Swepco is a pillar in the Porsche engine building and Indie shops community so you may have to call around if you can't find it online. The Swepco 714 was the factory trans fluid back in the early 2000 per friend who owned a GT2. Dieter at Andial indicated such.
Porsche Tuner ANDIAL Sold to Porsche Motorsport North America
https://flatsixes.com/cars/tuned-porsch ... h-america/
At 14:00 in Leno's video. Jay is not familiar with the 306. The rating is API CI-4/SM/SL so not just for older Porsche's as he assumes.
Category Status Service
SM Current For 2010 and older automotive engines.
SL Current For 2004 and older automotive engines.
SWEPCO 306 Supreme Formula Engine Oil - Video In Swepco's Link
https://www.swepcolube.com/products/swe ... ngine-oil/
SWEPCO 308 Premium Plus Diesel Engine Oil
BeerDeer
Year and Model: 1996 and Volvo 850
Has thanked: 2 times
Been thanked: 3 times
Post by BeerDeer »
MoVolvos wrote: 27 Sep 2024, 13:14 .
Try the ATP AT-205 if you think the leak is from a rubberized type of seal. After pouring the entire bottle in the 03 S80 T6 transmission I realized there was no drip the following oil change. That drip always migrates down the underside of the car during driving and never leaves a drop in the driveway so tend to forget about it.
That seal in the After photo seams be have been rejuvenated a bit. Is for the engine also.
ATP Automotive AT-205 Re-Seal Stops Leaks, 8 Ounce Bottle
https://www.amazon.com/ATP-AT-205-Re-Se ... VW1LM?th=1
Is using "ATP AT-205" or any other "Re-Seal" brand safe?
Here in Finland, we have Red Line Seal Saver.
BeerDeer
Post by BeerDeer »
MoVolvos wrote: 27 Sep 2024, 13:56 .
Let me see if I can ship it to Finland.
Right now, I've been using 5W40 Quartz 9000 with X-1R additive.
MoVolvos
Post by MoVolvos »
BeerDeer wrote: 28 Sep 2024, 05:46
I have used it in several cars without issue. They have been around for a long time. It was watching Scotty Kilmer's that had me give it try initially. As for motor oil my preference is for diesel motor oil.
MoVolvos
Post by MoVolvos »
xanthefin wrote: 08 Jan 2024, 13:42 Cars costing 1k or 10k are not to keep in money wise value as collectibles and in repairs you stop thinking car value to be honest. You either do the job or dont (want pay for the job or make the effort).
As usually you lose that imaginable money value of the car in insurances, petrol, taxes etc.. just to keep or run it anyway with any car.
Though this is just my philosophy...
BTW for tick tock sounds previous owner of my 850 had forgotten completely o rings from injectors somehow.
I would go with suggested attempt test with cleaning stuff if tapping goes away or mostly less. I would agree with misha and others here this is most likely lifters as i dont hear clonk like MoVolvos shared Rod Knock video example i do and it goes away in higher rpm unlike clonking Rod Knock.
Initially I thought it was the ticking from the oil cavitation of a bad oil pan O-Ring like that on my 00 S70. The combination of Kirkland Costco 15W40 dino diesel oil and additives, it eliminated the sound. When it gets bad it could sound like a rod knock as it's caused by oil starvation then. Couldn't find a video on the O-Ring tick so the O-Ring knock :lol:. From the video provide above in OP post it's not likely the tick of the oil pan O-Ring.
BeerDeer
Post by BeerDeer »
New update;
Another oil change, with Liquid Moly Oil Saver with premium oil 5W-40 https://lubricants.catalog.totalenergie ... 0-sn-5w-50
Additives with; https://x1rcorp.com/product/engine-trea ... rate-8-oz/
No change. Ticking still here. During driving it feels it goes away, but idle you can hear it. Injectors or Lifters. I'm not sure.
Should I put another can of https://x1rcorp.com/product/engine-trea ... rate-8-oz/ or should I put another additive?
There´s also; https://www.liqui-moly.com/en/us/viscop ... html#20206
Viscoplus for Oil;
optimum lubrication under all operating conditions
optimum oil pressure under all operating conditions
reduces oil consumption
reduces engine noise
minimizes viscosity loss
OR; https://www.liqui-moly.com/en/us/cera-t ... html#20002
Cera Tec:
excellent high and low temperature behavior
chemically inert
use with diesel particulate filters
increases smooth operation
stable under extreme pressures
OR; https://www.liqui-moly.com/en/us/hydrau ... tion-title
Hydraulic Lifter Additive;
dampens hydraulic lifter noise
ideal with turbochargers and catalytic converters
cleans oil passages
improves the lubrication properties
Should I try the Hydraulic Lifter Additive for my VOLVO 850 1996?
Thank you so much to everyone here for your help and support. I’m truly grateful for your kindness and generosity. Your assistance means a lot to me, and I deeply appreciate it!
Clemens
Has thanked: 500 times
Been thanked: 228 times
Post by Clemens »
The injectors are really loud, for a while I thought my lifters were ticking until one of the lifters really started to tick. The lifters are louder and throatier, the injecors sound like a loud sewing machine.
It usually helps to drive above 4000 rpm for a while, the lifters seem to free from buildup through the high rpms.
1996 855 R,
2010 V70 D5,
Clemens
Post by Clemens »
+1 on ATP 205. It fixed my RMS leak for years. I only replaced the RMS because I already hat the tranny out while manual swapping.
In your case, the PCV surely is the main reason for the leak.
1996 855 R,
2010 V70 D5,
BeerDeer
Post by BeerDeer »
Clemens wrote: 26 Nov 2024, 02:57 The injectors are really loud, for a while I thought my lifters were ticking until one of the lifters really started to tick. The lifters are louder and throatier, the injecors sound like a loud sewing machine.
I can try using https://www.liqui-moly.com/en/us/hydrau ... tion-title
What do you think? I seen people using Liquid Moly and got good results. I think worse its not going to do right?
DennisCA
Year and Model: 1996 850
Has thanked: 6 times
Been thanked: 70 times
Post by DennisCA »
I also use 5W40 full synth oil in my Volvo, also in my Yaris and Saab 900. I do not believe engine oil additives do much unless you already got a problem then maybe it's worth trying. 5W40 seems to be very common in the nordic countries. My Mazda uses 5W30, the odd one out.
I try and avoid having those problems in the first place by replacing filter and oil every 10,000km or every year, whichever comes first.
