https://stackoverflow.com/questions/533 ... tall-stuckmoogletimes wrote: ↑10 Jul 2024, 19:44 Unfortunately, I can't even get past the first part. Specifically SQL setup gets stuck on the same part. "SqlEngineDBStartConfigAction_install_configrc_Cpu32". Or "SqlEngineDBStartConfigAction_install_configrc_Cpu64".
VIDA 2014D_Repack install on Windows 10, any version.
- RickHaleParker
- Been thanked: 958 times
Re: VIDA 2014D_Repack install on Windows 10, any version.
Dutchtouchmarine
- Year and Model: 1999 C70, T5R
Hi guys,
Installing as directed but problems on 03_patch.cmd
“Tskill.exe” is not recognized as an internal or external command, operable program or batchfile
Anybody an idea on how to continue?
Dutchtouchmarine
Also, coming into Vida on chrome, what should be the username?
kalle37
- Year and Model: 18 V60 T 5
Doesn't get past this no matter what I try. The service "SQL Server (VIDA)" is just stuck in "Starting" status, if I kill it in any way, the setup just unstucks and fails.
Only Windows 7 doesn't get stuck at this part for me, which is what I'm gonna have to live with. Got it working on Windows 7 Pro x64 SP1 with IE10, albeit with some security alterations in the IE settings so that it wouldn't give me a blank screen on Vida localhost.
Tried it on fresh installs of Windows 10 22H2 stock and debloated(with custom unattend debloater file), Windows 10 20H2 stock and debloated, and Windows 11 23H2, stock and debloated. All of 'em got stuck at this part. Haven't tried yet on Windows 8 or 8.1.
Might try 8.1 later but I've already wasted the whole day on this and need to sleep hahah
Gonna skip trying it on win8 as I just hate it anyway and would rather stay on win7. Am thankful and happy that I got it working at all, but I would very much like to have it working on 10 or 11 because many other apps don't like 7 anymore.
Did you solve this problem? I have exactly the same problem.
- Has thanked: 2652 times
- Been thanked: 1242 times
Did you look at this?
RickHaleParker wrote: ↑18 Aug 2024, 02:22https://stackoverflow.com/questions/533 ... tall-stuckmoogletimes wrote: ↑10 Jul 2024, 19:44 Unfortunately, I can't even get past the first part. Specifically SQL setup gets stuck on the same part. "SqlEngineDBStartConfigAction_install_configrc_Cpu32". Or "SqlEngineDBStartConfigAction_install_configrc_Cpu64".
lookforjoe
- Year and Model: 1991 743
- Been thanked: 3 times
Thank you for laying this out - I had to replace my old Toshiba and the DVD I have won't install on the new (old) Satellite (Windows 7, 64bit) I bought to replace it, so I followed your directions in the first post & downloaded the .iso & the patch.
Problem I have, is I can't left click on the downloaded .iso & get it to mount. I'm not a usual PC user, so I just don't know what else to try to get it to mount so I can run the next steps.
lookforjoe
Was informed a separate piece of software is required in Windows 7 in order to access a .iso file. Working on that.
Qual o Username a ser utilizado na inicialização do Vida?
Realizei a instalação aparentemente tudo certo e veio pra minha tela três opções de acesso.
Sendo uma delas a que aparentemente deu mais certo, solicita um Username para acessar o software.
Alguém tem esse Username e se a senha combina com esse "username".
