Need help to identify what module is this. V70 2001
nfreitas377
Year and Model: 2001 V70 T5
Post by nfreitas377 »
Hello fellow Volvo friends, I'm in a process of restoring to OEM standards this Volvo V70 T5 2001 in Brazil and while I was revising all the electrical wiring, I found this module which I don't know what it is. It is located at the left side, inside the fender. It is relatively close to REM but does not seem to be connected at it. Also, it is conneceted to a auxiliary battery. So far, it looks like it is some sort of tracking system and I believe it isn't oem. Does anyone can confirm it is NOT an OEM part nor OEM acessory?
Thank you for your help!
Nuno
nfreitas377
Just found it... It is indeed a tracking system from 2002... will remove and save it as a souvenir! :D :D
jonesg
Year and Model: 2004 V70
Has thanked: 73 times
Been thanked: 532 times
Post by jonesg »
we will still find you. !
