Plastic Parts Repair
This topic is in the MVS Volvo Repair Database » How to Fix Interior Plastics
Grantkat
Year and Model: 1999 s70 GLT
Has thanked: 47 times
Been thanked: 43 times
Volvo Repair Database Plastic Parts Repair
Post by Grantkat »
I did a thread on repairing my glovebox kick panel. here is a follow on where I created my own ABS Slurry to repair a pillar trim:
Please note the following:
1) You cannot use spare trim parts to create the slurry if they are stamped PC + ABS. That means is a mix of polycarbonate and ABS and wont dissolve in MEK or Acetone.
2) You should do this in a ventilated area, these chemicals are harmful. use at your own risk.
now onward:
I had a broken pillar trim and wanted to repair it, instead of dropping $175.00 on a new one. for this task I bought a 32 oz can of Methyl Ethyl Ketone (MEK) $14.95 and a spool of beige colored ABS #D printer filament. Note you can also use Acetone, which is easier to come by and can be found in any hardware or big box store, in the paint section. It should be located where you find mineral sprits in those stores. The color is not exact but doesn't need to be, it just needs to be close because the filament somewhat transparent when applied so it tends to blend in.
1999 S70 GLT ~193k
2014D VIDA/DICE
2007 Jeep Wrangler Unlimited ~ 315K
2008 Lincoln MKX ~130k
2008 Toyota Sequoia ~ 252k
Powered by coffee, stripped bolts, and questionable decisions.
Grantkat
Post by Grantkat »
I cleaned out a glass jar with a metal lid. this is important, you need metal or glass as these solvents dissolve alot of plastics or other materials. any pickle jar. mason jar etc will work. I used a salsa jar. I cut the ABS filament into small pieces and put then in the jar then added MEK and put the lid on. At first they stuck together in a clump which I broke up by mixing it and breaking it up with a wooden skewer (the kid you make shish kabobs with). I mixed them up and broke them up about once any hour for a few hours then let it sit over night. Make sure you keep the lid on when not mixing. The next moring I had a slurry, about the consistency of pudding.
My recipe was 20 grams of ABS pieces and 50 ml of MEK.
50 ML of MEK is equivalent to 10 teaspoons of MEK.
Examples of piece in the picture of the scale.
1999 S70 GLT ~193k
2014D VIDA/DICE
Grantkat
Post by Grantkat »
here is the broken part to repair followed by the repair itself.
Note in this case I also used some flat nails from a nail gun as stretchers across the breaks to fortify them. It worked extremely well.
1999 S70 GLT ~193k
2014D VIDA/DICE
Grantkat
Post by Grantkat »
I built up the patches from the back along with the nails to give it some strength
Here is the end result from the front. Not perfect but over all I am happy with the result.
1999 S70 GLT ~193k
2014D VIDA/DICE
Has thanked: 1497 times
Been thanked: 3809 times
That is beautiful, beautiful work!
Can you link us to the abs filament you used as that colour match is perfect.
Grantkat
Post by Grantkat »
Abscate,
I was searching for this post, as i had to make some more "goo". I realize i never linked the ABS filament...I cant seem to get a decent link that isnt a mile long
here is the name and type..if you search this on amazon you find it quickly:
Gizmo Dorks 3 mm ABS Filament, 1 kg for 3D Printers, Natural Beige
1999 S70 GLT ~193k
2014D VIDA/DICE
Naturally purchasable through the link above …
abs to fix trim
Matt…another one for the VRD, @Grantkat did a great write up on documenting abs mek slurry for beige plastic repair.
VPrints
Year and Model: 1998 S70 Turbo
Has thanked: 19 times
Been thanked: 15 times
Post by VPrints »
Love this
98 S70 Turbo
07 XC70
95 945 NA
NC855R
Year and Model: 1997 850 R
Has thanked: 45 times
Been thanked: 28 times
Post by NC855R »
This is perfect timing for this solution. Working to get my headliner out of my 855 and the first thing I touched, the A-pillar trim, just shattered. Partly because when the windshield was replaced the adhesive is on the front part of the trim. Thanks for this solution! No to go razor blade the adhesive from the trip to get it to come out.
