Hi everyone,
The passenger cv shaft in my c70 has started to go and needs replacement and I had a few questions.
Does the cv from the 850 fit the c70? Or are the dimensions different.
I have seen mentions of people rebuilding their own cvs and I was wondering if there was a kit to do this?
Many thanks
Dan
CV Questions
- dandanboi25
- Year and Model: 200 c70 coupe
- Has thanked: 1836 times
- Been thanked: 1709 times
When you say the axles are starting to go, what do you mean? Are they clicking/clunking when turning or rotating, or is it just the CV boots that are bad?
What is the mileage on the axles/car and are they Volvo originals.
Is your C70 an turbo or not and what year is it? If it is a 99- the axles cannot be swapped as the -98 use a nut to hold the axle in place, but the 99- use a bolt to hold it in place on the hub. I don't recall if you can interchange them using the correct hardware for the axle.
Typically you can fit turbo axles to non-turbo cars but not the other way around.
Some early 850's had a different number of splines on the hub end.
Is the car a 4 speed auto or 5 speed auto, or is it a manual?
So lots of things to check.
- Krons
- Has thanked: 193 times
- Been thanked: 202 times
I know nearly all here on the forum recommend Volvo OEM, but I’ve had good results with TRQ CV shafts for pretty reasonable prices. Can always keep/rebuild the originals for spares.
08 C702.5T (sold)
The non-Swedes:
08 C702.5T (sold)
The non-Swedes:
- dandanboi25
Thankyou for the swift responses.
I probably should have given some more info, its a 2000 c70 coupe t5, 270k km, 4 speed auto aw50 and I am fairly sure its an oem cv. Currently The cv creaks/clicks upon engaging/disengaging the throttle and has recently started clicking while turning.
Wondering what the process for rebuilding a cv is like and where I can get the parts from?
Many Thanks
Dan
Many Thanks
Dan
- Has thanked: 1497 times
- Been thanked: 3810 times
It will need a 1999 2000 axle , the - 1998wont fit. A breakers yard is a good source for a solid part.
jmartin919
- Year and Model: S70 GLT SE 2000
- Has thanked: 94 times
- Been thanked: 39 times
How would you know if the axle is good if you pull it from a yard?
'00 S70 GLT SE
'82 MB 380SL
'11 MB E350 Sport
'84 Chevy C10
'93 850 GLT NA SOLD
'82 MB 380SL
'11 MB E350 Sport
'84 Chevy C10
'93 850 GLT NA SOLD
- Goupil
- Year and Model: 98' V70 LPT
- Has thanked: 30 times
- Been thanked: 112 times
GKN Lobro is the OEM for shafts I think ? Sadly the turbo manual -98 ones are quite hard to find
1998 Volvo V70 B5254T M56
1994 Volvo 945 B230FT M90
1985 Volvo 240 B230E
jmartin919 wrote: ↑26 Mar 2025, 06:10 How would you know if the axle is good if you pull it from a yard?
From the crushed in back with Hyundai in reverse stamped into it
The Axle shaft number tabulation thread.
viewtopic.php?t=94409&hilit=Axle+shaft+ ... n&start=10
- Sveedy
- Has thanked: 417 times
- Been thanked: 457 times
Technically you don't. But if the boot is not torn, then I usually take the bet that the axle is good.jmartin919 wrote: ↑26 Mar 2025, 06:10 How would you know if the axle is good if you pull it from a yard?
1999 V70 GLT
1999 V70 GLT
