CV Questions
dandanboi25
Year and Model: 200 c70 coupe
CV Questions
Post by dandanboi25 »
Hi everyone,
The passenger cv shaft in my c70 has started to go and needs replacement and I had a few questions.
Does the cv from the 850 fit the c70? Or are the dimensions different.
I have seen mentions of people rebuilding their own cvs and I was wondering if there was a kit to do this?
Many thanks
Dan
Has thanked: 1836 times
Been thanked: 1709 times
When you say the axles are starting to go, what do you mean? Are they clicking/clunking when turning or rotating, or is it just the CV boots that are bad?
What is the mileage on the axles/car and are they Volvo originals.
Is your C70 an turbo or not and what year is it? If it is a 99- the axles cannot be swapped as the -98 use a nut to hold the axle in place, but the 99- use a bolt to hold it in place on the hub. I don't recall if you can interchange them using the correct hardware for the axle.
Typically you can fit turbo axles to non-turbo cars but not the other way around.
Some early 850's had a different number of splines on the hub end.
Is the car a 4 speed auto or 5 speed auto, or is it a manual?
So lots of things to check.
Krons
Has thanked: 193 times
Been thanked: 202 times
Post by Krons »
I know nearly all here on the forum recommend Volvo OEM, but I’ve had good results with TRQ CV shafts for pretty reasonable prices. Can always keep/rebuild the originals for spares.
08 C702.5T (sold)
The non-Swedes:
Vova585
Has thanked: 155 times
Been thanked: 141 times
Post by Vova585 »
I have a good luck with GKN brand. Also worth checking local offers. .maybe someone can professionally rebuild it for you.
dandanboi25
Thankyou for the swift responses.
I probably should have given some more info, its a 2000 c70 coupe t5, 270k km, 4 speed auto aw50 and I am fairly sure its an oem cv. Currently The cv creaks/clicks upon engaging/disengaging the throttle and has recently started clicking while turning.
Wondering what the process for rebuilding a cv is like and where I can get the parts from?
Many Thanks
Dan
Has thanked: 1497 times
Been thanked: 3810 times
It will need a 1999 2000 axle , the - 1998wont fit. A breakers yard is a good source for a solid part.
jmartin919
Year and Model: S70 GLT SE 2000
Has thanked: 94 times
Been thanked: 39 times
Post by jmartin919 »
How would you know if the axle is good if you pull it from a yard?
'00 S70 GLT SE
'82 MB 380SL
'11 MB E350 Sport
'84 Chevy C10
'93 850 GLT NA SOLD
Goupil
Year and Model: 98' V70 LPT
Has thanked: 30 times
Been thanked: 112 times
Post by Goupil »
Vova585 wrote: 25 Mar 2025, 19:38 I have a good luck with GKN brand. Also worth checking local offers. .maybe someone can professionally rebuild it for you.
GKN Lobro is the OEM for shafts I think ? Sadly the turbo manual -98 ones are quite hard to find
1998 Volvo V70 B5254T M56
1994 Volvo 945 B230FT M90
1985 Volvo 240 B230E
jmartin919 wrote: 26 Mar 2025, 06:10 How would you know if the axle is good if you pull it from a yard?
From the crushed in back with Hyundai in reverse stamped into it
The Axle shaft number tabulation thread.
viewtopic.php?t=94409&hilit=Axle+shaft+ ... n&start=10
Sveedy
Year and Model: 96 850 Turbo
Has thanked: 417 times
Been thanked: 457 times
Post by Sveedy »
Technically you don't. But if the boot is not torn, then I usually take the bet that the axle is good.
1999 V70 GLT
