Aluminum wheel corrosion welded (?) to hub
beewstew
Year and Model: 2004 xc70
Has thanked: 34 times
Been thanked: 5 times
Post by beewstew »
Working on a poorly maintained 2004 xc70 - tonight it was brakes. The passenger rear wheel seems welded (by corrosion?) to the hub. With lugnuts out I've been pounding on the rim with a rubber hammer for two days - I've used most of a can of liquid wrench in the lugnut holes and the seam between the hub and the wheel. Any other tricks for breaking an aluminum rim loose from a steel hub?
Edit: resolved. Lowering half of a tire with loose lug nuts onto a 4x6 wasn't enough to break the wheel loose from the center hub flange. Hitting an 8' 4x4 post with a maul, with the wood bearing on the rim - across and underneath the rear axle, ended up being successful.
While hammering, a lock ring fell off some part of the rear axle/hub/shock etc. Thoughts on where it fell from?
Thanks for all the suggestions.
This lock ring fell off while I was pounding. Wonder if it's important?
4x4 post, running under the rear axles. Stacked 2x lumber so that the post hits the rim, not the tire, when I hit the other end of the post with a maul.
DavidE7
Year and Model: 01-07 V70, S60, XC70
Has thanked: 67 times
Been thanked: 93 times
Post by DavidE7 »
Strong heal kicks to the tire on alternating sides about a hundred times to rock the wheel back and forth to break the corrosion. Don't kick hard enough to knock the car off the floor jack, jack stands, or lift supporting the car. I found the kicks work better if you get under the car and kick the tire outward but the risk of the car falling on you is huge! I haven't had luck with sledge hammers because they just bounce off the tire.
David E
2001 Moondust V70 2.4 293,000 miles
2001 Nautic Blue V70 2.4 231,000 miles
2004 Nautic Blue XC70 2.5T 258,000 miles
new: 2004 Black Saphire V70R 193,000 miles
2007 Titanium S60 2.5T 277,000 miles
2007 Magic Blue S60 2.5T 233,000 miles
2007 Silver V70 2.4 203,000 miles
P2 Volvos for every person in my family
vtl
Year and Model: 2005 XC70
Has thanked: 130 times
Been thanked: 686 times
Post by vtl »
Take another wheel, swing it and smack against your stuck wheel. I.e. what you do with rubber hammer, but now with sufficient mass and inertia.
Krons
Has thanked: 198 times
Been thanked: 215 times
Post by Krons »
There is an easier way. Loosen lug nuts to barely touching the wheel and slowly go for a drive, around a corner or roundabout is ideal. It’ll eventually break free.
I’ve learned to apply a light film of grease (or anti seize) to areas where wheel touches the rotor after that.
08 C702.5T (sold)
The non-Swedes:
dikidera
Year and Model: S60 2005
Has thanked: 68 times
Been thanked: 187 times
Post by dikidera »
Krons wrote: 26 Mar 2025, 21:55 There is an easier way. Loosen lug nuts to barely touching the wheel and slowly go for a drive, around a corner or roundabout is ideal. It’ll eventually break free.
I would add to aim at the potholes.
vtl
Post by vtl »
dikidera wrote: 27 Mar 2025, 01:34
I would add this is a call for troubles. Just take that spare wheel and smack the seized wheel off. Always works.
Krons
Post by Krons »
Too much force. I have a roundabout a few hundred yards from my house. One slow (10-15 mph) trip around and my seized wheel was loose.
08 C702.5T (sold)
The non-Swedes:
Krons
Post by Krons »
vtl wrote: 27 Mar 2025, 05:18
I’ve hurt myself or my cars too many times ‘smacking’. :oops:
Loosening the lug bolts (with all of them still threaded well onto the hub) and driving at 10-15 mph is not going to damage anything.
08 C702.5T (sold)
The non-Swedes:
dikidera
Post by dikidera »
*in case of extreme welding* then :D
Been thanked: 4065 times
Worst one I ever had…4x4 long timber under car, propped to bear on wheel, then sledge from other side
