I replaced my original 1992 speedo with a V70 P80 speedo with the digital kilometer readout. Now its acting funny, not showing the correct speed etc; does this dash pull the speed from the gearbox or from the ABS sensors?
I did not have this issue with the previous dash.
Thanks in advance!
Speedo acting funny after swap. Volvo 850 '92 GLT
- misha
- Has thanked: 155 times
- Been thanked: 432 times
1997 & 1998 s,v,c or xc70 instrument clusters are not interchangeable with pre '96 850.
It will work ONLY on '96 & '97 850 which originally had VDO clusters.
Also...'99 & '00 s,v,c or xc70 instrument cluster will not work in any 850 nor pre '99 70 series cars because of CAN protocol introduced.
'71 144 S
'73 144 De Luxe
'78 244 DL
'78 244 DL
'79 244 GLE
'85 340 GLS
'71 144 S
'73 144 De Luxe
'78 244 DL
'78 244 DL
'79 244 GLE
'85 340 GLS
- misha
Speedometer on pre '96 cars takes analog output from speed sensor on gearbox.
'96 and later cars speedometer takes digital output from abs/tracs module.
I guess that you could tap into front wheel abs sensors but i can't verify that signal would be correct.
And you will need pre '99 cluster ONLY from 70 series p80.
'71 144 S
'73 144 De Luxe
'78 244 DL
'78 244 DL
'79 244 GLE
'85 340 GLS
'71 144 S
'73 144 De Luxe
'78 244 DL
'78 244 DL
'79 244 GLE
'85 340 GLS
- misha
There is Yazaki cluster for 850,looks similiar to 70 series cars cluster but it is not interchangeable with VDO and they are pretty rare...at least on B5254S cars:koralski wrote: 28 Mar 2025, 16:51 Is there even another option? All clusters i see for a '94 are VDO.
'71 144 S
'73 144 De Luxe
'78 244 DL
'78 244 DL
'79 244 GLE
'85 340 GLS
'71 144 S
'73 144 De Luxe
'78 244 DL
'78 244 DL
'79 244 GLE
'85 340 GLS
- Has thanked: 2199 times
99- clusters are not interchangeable with other cars at all. The are loaded with the Vin#. They cannot be re-programmed according to Volvo (unless someone knows how). They are supposedly a one shot program circuit board. It may be able to work assuming the same transmission is fitted, but you cannot talk to the ECU/TCU unless the Vin#'s match in both.
- koralski
- Year and Model: '92 850
- Been thanked: 7 times
No, my car doesn't have this cluster. I am going to splice the wires and fingers crossed it will work!misha wrote: 28 Mar 2025, 17:43There is Yazaki cluster for 850,looks similiar to 70 series cars cluster but it is not interchangeable with VDO and they are pretty rare...at least on B5254S cars:koralski wrote: 28 Mar 2025, 16:51 Is there even another option? All clusters i see for a '94 are VDO.
By the way, do you know if holding the hour and minute button changes from MPG to L/100km?
- misha
Never tried...but it should work.
'71 144 S
'73 144 De Luxe
'78 244 DL
'78 244 DL
'79 244 GLE
'85 340 GLS
'71 144 S
'73 144 De Luxe
'78 244 DL
'78 244 DL
'79 244 GLE
'85 340 GLS
- 615 Views
- 1981 Views
Last post by CarCapers
- 14 Replies
- 3136 Views
Last post by Kuhnboy
- 1366 Views
Last post by Faheyk1981
- 10 Replies
- 6025 Views
Last post by misha
