As per title. Found a fun new gremlin on the S60 today. Intermittent right now but bound to get worse.
Every time my wipers are engaged, the pump is running. Doesn't matter what speed setting. I've read it can actually be a bad headlight washer motor causing this. Any truth?
Need to look at the wiring diagram to begin troubleshooting, just shooting it out there to see if anyone else had this. My guess is a bad stalk possibly just need to isolate and begin troubleshooting.
04 S60 - Windshield Washer Pump Always on with wipers Topic is solved
- br0dy519
- Year and Model: 2004 XC70
- Has thanked: 132 times
- Been thanked: 126 times
04s60 2.4
04xc70 2.5t
04xc70 2.5t
- br0dy519
Solved!
Mine and @cn90 's hunches were correct. Stalk was the issue. Followed this video and cleaned contacts on the stalk's control board. Appears grease inside with the little slider can gum up the control board contacts. Easy peasy 15 minute and FREE repair. Did the turn signal stalk as well since I had everything apart. Just used 99% Iso alcohol and a white eraser.
04s60 2.4
04xc70 2.5t
04xc70 2.5t
- ljsommar1
- Year and Model: 2002V70
- Been thanked: 8 times
I purchased a used unit from Erie scrapyard and installed this afternoon, 15 minute job and it resolved the issue.
Thanks to everyone for the help. It will be nice to have wiper delay for sure.
- 36 Replies
- 24713 Views
Last post by StickyPocket
- 341 Views
- 527 Views
Last post by matthew1
- 4430 Views
Last post by bmdubya1198
- 21 Replies
- 4978 Views
Last post by cn90
