'97 850 2-1-1 SRS code
Chuck W
Year and Model: 97 854 T5
Has thanked: 96 times
Been thanked: 337 times
Post by Chuck W »
So, her car ('97 GLT) has started to show an SRS light and the code is 2-1-1. DS airbag short circuit. It comes back after being reset (Autel EU702)
No other issues, and I noticed that the airbag clock-spring cable to the airbag was getting a little funky when I had the wheel off for the dash swap a little while back. That sound like a likely suspect?
Has thanked: 1850 times
Been thanked: 1712 times
I would agree it sounds like the clock spring. Does the horn work ok? If it does then it does not mean the part for the airbag on the clock-spring is not bad, but if the horn does not work as well then it is definitely the clock-spring.
Chuck W
Post by Chuck W »
Yeah. The horn works.
Going to see if replacing the clock spring solves it.
Chuck W
Post by Chuck W »
Well, the SRS light hasn't been back since the last reset a few days ago. I think that clock spring cable is the suspect, so I have another one on the way.
Chuck W
Post by Chuck W »
Replacement clock-spring is here, but the SRS light has remained off. (Of course).
If it rears its head again, I'll swap things out. Until then, I have other projects I need to spend my time on.
