- rudsaki
- Year and Model: 1998 S70 T5
- Has thanked: 26 times
- Been thanked: 15 times
That is part of standard installation along with brackets. I'm not quite brave enough to go tape alone.
Previous Volvos
1969 142s Blue manual.
1966 122s Yellow with the 69 motor in it
1971 144s Red . Also the '69's motor
1973 P1800ES Aqua Manual with OD.
1971 142E Light Blue manual with OD.
1979 244DL Brown manual. Marriage/baby car. Divorce, Ex got it and sold it to my father!
1968 1800s White manual/OD. Strong runner. Killed by a '66 T-Bird
1984 242 Turbo Intercooler Silver Manual/OD
1966 1800s White Manual/OD
1985 740 Turbo Intercooler Silver Manual/OD Sold to Nephew
- foggydogg
- Has thanked: 83 times
- Been thanked: 402 times
Robert is home for a few days, he does like talking Volvo on the phone.
- rudsaki
Turns out he has a store front on his webpage and had those brackets. $45 for 2 including shipping which is pretty good compared VIVA new ones for $90 or so. Now I just need the right size screws which he lists the Volvo part number.
Previous Volvos
- Goupil
- Year and Model: 98' V70 LPT
- Has thanked: 30 times
- Been thanked: 112 times
Replaced the plastic thing at the front with a non broken one. Hood now opens on the first pull of the level, a very welcome improvement.
(despite the looks, this is not a Rolls royce
Then got unto the front brakes because I'm tired of them absolutely screaming at low speed. Found two small pebbles in the piston boot and pads with a lip. Chamfered the pads, back together with grease where needed, hopefully should be silent now
1998 Volvo V70 B5254T M56
1994 Volvo 945 B230FT M90
1985 Volvo 240 B230E
- xanthefin
- Year and Model: 1997 850
- Has thanked: 106 times
- Been thanked: 130 times
Did change summer tires and old known guest was found, bad cv boot.
So little time later got to use lift (very nice first time experience this luxury)
So this choice comes that this side was done same time as other side but.. other side has split boot and its still fine. This bad boot was one of those which you pull just over axle. I dont know brand of it as i was just who took axle out and put it back with new boot.
I did then put crimp but.. i got light bulb moment that i have done long time something wrong so i searched right tool and not the one which looks similar.. bingo it has extra smashing hand so did then buy next day right tool for the job. Now looks more like it would work longer and it crimps tighter as a plus too.
Lets look the driver side.. uh oh. Crimp didnt hold (this been pain keep.. the split boot is way too big 80-110mm.. way too big!.. correct size is 80 or 90mm and i used 80 which is 80..89mm which after gluing was tight to put with little expanding. not too much work.. )
.. after picture i did crimp it slightly more still.
As another bonus i found extra metal sheet in my car!
Didnt get it easily so i left there as doesnt rattle.. then in future i deal with it.
Later when better time and inspiration.. engine valve stem seals, belt, heater core etc.
RedBrickCollector
- Year and Model: 1997 850 T-5 Wagon
- Has thanked: 40 times
- Been thanked: 28 times
Where do you get a replacement for the ECT connector?
'97 950 T-5 Wagon
'89 and '95 Daihatsu Feroza
yanga001
- Has thanked: 59 times
- Been thanked: 110 times
Got some goodies from the scrapyard. A nautic blue door and bumper cover.
Noted that the 99-00 XC70 has a different rear wiper motor from the 98 base model. It is plastic but should still fit the same. Pulled said motor for my own restoration project.
Found some window wind deflectors for 18cad total which was nice.
2008 S60 2.5T Auto (Sold)
- Goupil
Grabbed one from a spare loom, replaced the seals with those https://www.printables.com/model/927466 ... al-3523813
Aliexpress has some pigtail ones as well, but seller cancelled the one I tried buying
