Started prepping the trusty s60 for sale. Need to do an oil change, rear rotors and pads, and detail it. Put a fair amount of money into the car but it has been good to me for the past two years of ownership.
Car has been great to me, but i've inherited a 12' pilot fully loaded. That needs a bit of work, but the size, fuel economy (9L/100km premium normally vs 9.8-11), and towing capacity has me set. It too will need a timing belt and water pump soon, cant escape that.
The older volvos in the fleet will see a lot more love coming up.
yanga001
- Has thanked: 62 times
- Been thanked: 115 times
2008 S60 2.5T Auto (Sold)
- br0dy519
- Year and Model: 2004 XC70
- Has thanked: 132 times
- Been thanked: 126 times
Where are you located? You can message me if you feel more comfortable doing that. I may be interested in your car as is.yanga001 wrote: 20 May 2025, 12:41 Started prepping the trusty s60 for sale. Need to do an oil change, rear rotors and pads, and detail it. Put a fair amount of money into the car but it has been good to me for the past two years of ownership.
04s60 2.4
04xc70 2.5t
04xc70 2.5t
- darylrobert
- Year and Model: V70 240 740t xc70
- Has thanked: 6 times
- Been thanked: 46 times
i am almost finished a front (cat cam) camera installation, activated by a contactless proximity sensor mounted on the gear stick (manual)
the sensor activates when a metal object (gear selector arm) swings into range
SN04-N 4mm PNP Approach Detect Inductive Sensor Proximity Switch DC 10-30V
Alpine ilx-702d headunit
- BlackBart
- Has thanked: 967 times
- Been thanked: 923 times
I just sent an order in to FCP including a RF axle seal, Corteco 9143885. Is that the correct one? (2004 XC70). They have two versions, but this appears to be my application. I wrote them to verify. Not sure I need it, but if the axle is coming out, I felt I should have it on hand.
Thanks -
Thanks -
- BlackBart
FCP wrote right back - very nice - to say yes, that’s the correct axle seal. I had them add the updated intake banjo bolt while I had them on the line.
- Krons
- Has thanked: 198 times
- Been thanked: 215 times
Started tear down of the front suspension on the 05 XC90. LCAs, sway links, in/out tie rods, ball joints, CV shafts too while I’m there (208k miles). Did loaded struts 7k miles ago and was clear rest of suspension needed done.
Driving in ball joints gets me every time. May take the steering knuckles to a local shop in morning to have them install them. I recall on here someone used a short piece of 1.5” capped steel pipe. Home Depot only had PVC in that size lol. May try Menards, local O’Reilly may have a tool too.
08 C702.5T (sold)
The non-Swedes:
08 C702.5T (sold)
The non-Swedes:
- Krons
I surrendered and paid the local shop $90 to install the ball joints. XC90 drives much better, the steering wheel is now straight vs slight cant to it.Krons wrote: 30 May 2025, 22:26 Started tear down of the front suspension on the 05 XC90. LCAs, sway links, in/out tie rods, ball joints, CV shafts too while I’m there (208k miles). Did loaded struts 7k miles ago and was clear rest of suspension needed done.
Bad news at alignment shop…I was running out of time for my 4pm appt (as well as energy and emotional fortitude) and skipped the inner/outer tie rods as the outers looked fairly new. Whelp the inners have a teeny bit of play in them. Frustrating as I checked them and did not feel any. So we’ll tackle that one another day, at least no bill for an alignment…
08 C702.5T (sold)
The non-Swedes:
08 C702.5T (sold)
The non-Swedes:
- 12198 Replies
- 1684776 Views
Last post by RedBrickCollector
- 97 Replies
- 210475 Views
Last post by br0dy519
- 59 Replies
- 62551 Views
Last post by smacknab
- 7109 Views
Last post by xHeart
- 12349 Views
