Hello once again, I did a rebuild on my NA in the past 2 weeks, due to a leaking valve and blown head gasket(cyl 3-4), as mentioned in a previous post, so I took it apart, replaced everything that was busted and put it back together.
Now, with everything back in place, valve timing aligned, it cranks without a problem, but doesn't start. Haven't had a single problem like this before.
It probably isn't sparking, but i couldn't pull a spark plug to check, as I was alone and needed someone to crank from the inside.
I know the drill, cam sensor, ignition sensor and such, but is there anything else that I should pay attention when check tomorrow? Any heads-up will be greatly appreciated.
95' NA - Cranks, doesn't start
- Sveedy
- Has thanked: 445 times
- Been thanked: 479 times
The round plate that the rotor mounts to can be mistakenly indexed 180* off, which will cause a crank/no start situation.
1999 V70 GLT
1999 V70 GLT
fredt2
- Year and Model: 850 GLT 1995
- Has thanked: 2 times
- Been thanked: 7 times
Thanks, hadn't really thought about the rotor, I had checked the cam sensor round piece but not the rotor.Sveedy wrote: 21 May 2025, 18:39 The round plate that the rotor mounts to can be mistakenly indexed 180* off, which will cause a crank/no start situation.
- misha
- Has thanked: 155 times
- Been thanked: 432 times
Cam position sensor back plate too.Sveedy wrote: 21 May 2025, 18:39 The round plate that the rotor mounts to can be mistakenly indexed 180* off, which will cause a crank/no start situation.
'71 144 S
'73 144 De Luxe
'78 244 DL
'78 244 DL
'79 244 GLE
'85 340 GLS
'71 144 S
'73 144 De Luxe
'78 244 DL
'78 244 DL
'79 244 GLE
'85 340 GLS
fredt2
I don't think the cam sensor or the round part that bolts to the cam can be installed backwards, took it apart yesterday and found no way to put it reversed, the slots on the round part are offset, so it only works a certain way, don't know about the rotor tho
- misha
Not backwards but,just like the one behind distributor...it can go in ...in two ways.
One way is a no start.
'71 144 S
'73 144 De Luxe
'78 244 DL
'78 244 DL
'79 244 GLE
'85 340 GLS
'71 144 S
'73 144 De Luxe
'78 244 DL
'78 244 DL
'79 244 GLE
'85 340 GLS
fredt2
Well, this is embarrassing....
Turns out I wired the spark plugs in reverse order, in the process of disassembling the distributor i checked and saw that the wires were backwards.....put it back together correctly and she spun like a beauty, feels like a new car
- Sveedy
^ Far out ! It is a great feeling after doing all that work, and driving around in the fruits of your labor !
1999 V70 GLT
1999 V70 GLT
- 2514 Views
Last post by dandiman
- 10 Replies
- 4462 Views
- 28 Replies
- 7742 Views
Last post by 93ForMe
- 18 Replies
- 10417 Views
Last post by Ozark Lee
- 4245 Views
Last post by BestNana1485129
