Has thanked: 1850 times
Been thanked: 1712 times
Apologies for the delay in getting back to you on the weight of the wheel bearing.
I weighed my old Volvo wheel bearing in the replacement SKF box. In my case they did not include the 4 new E-Torx bolts or the later style bolt and washer axle retainer.
The bearing and box were 8.2lbs. I would allow possibly another 0.5lb or so for the 4 replacement mounting bolts and in your case the axle nut.
Hope that helps! I got my SKF bearings from Rock Auto. Maybe check if they can ship direct to you. Their shipping prices are usually very good to Canada and include border charges and import taxes.
RedBrickCollector
Year and Model: 1997 850 T-5 Wagon
Has thanked: 40 times
Been thanked: 28 times
Post by RedBrickCollector »
For a bunch of reasons (paint shop needing the thing rolling, etc) I'm going for a cheap used hub. That'll do until I replace the bearings, boots, and control arms as a set soon-ish
'97 950 T-5 Wagon
'89 and '95 Daihatsu Feroza
At least you have a way forward, even if it is short term.
Good Luck!
RedBrickCollector
Now that I'm paying closer attention to Robert's video on the wheel bearing and reading other threads I'm now considering that the lugs snapped because of a bad bearing. Sound before it happened is exactly as in his video.
'97 950 T-5 Wagon
Chieber
Year and Model: 1998 v70
Has thanked: 45 times
Been thanked: 30 times
Post by Chieber »
Kindly boyish but I installed fog lights, even though we rarely have a use for them here.
1/2 a shitbox V70 1998 2.5 NA
melmaclifeform
Year and Model: 2000 S70 GLT SE
Has thanked: 2 times
Been thanked: 7 times
Post by melmaclifeform »
Chieber, I think that fog lights just make any of these cars look better. Totally understand putting them in even if they're not needed!
2000 S70 GLT SE
1997 Volvo 850 T5
2011 Volkswagen Jetta SE
1999 Mazda Miata
Has thanked: 1505 times
Been thanked: 3818 times
Bonus 5 HP if you make the fog lights flash when you warn that Bimmerfest you are going by….
BlackBart
Has thanked: 927 times
Been thanked: 884 times
Post by BlackBart »
Chieber wrote: 22 Jun 2025, 09:36 Kindly boyish but I installed fog lights, even though we rarely have a use for them here.
They are quite useful on rainy nights on dark back streets.
Chieber
Post by Chieber »
I should go around every festival and flash my fog lights to gain as much hp as a turbo version.
Btw, anyone one knows what adjustment this knob does? It’s part of the cruise controle module.
DennisCA
Year and Model: 1996 850
Been thanked: 59 times
Post by DennisCA »
Today I removed the rocker panel cover on the right side. I am gonna remove both for inspection but I started with the right since I am going to start addressing the rust hole on the fender as well.
Those lower plastic pins where a real PITA to get rid off, someone said you could just push them in, but that did not help at all with removing them. I had to drill and cut everyone out. Not looking forward to working on the left side.
When I got it off there was a lot of dirt trapped inside. The rust situation doesn't seem too bad. It's mainly around the clips.
Not sure what's happened here though, looks like someone tried to lift it wrong.
Only rust found on the top side
All in all it doesn't look too bad. I'll do what I can to remove and convert the rust before painting with some epoxy base and soaking the sill in Dinitrol. Need to find new plastic push pins too. I hope the left side is in no worse shape than this.
