(Excuse the dog hair)
I used threaded rod, which was about 200mm long. You can substract 20mm for the two nuts and I think there was some additional length.
160mm might work, but you can probably use 1/2" threaded rod as well when you take additional care about the alignment.
P80 P2 Subframe Bushing installation with pictures 3507923
crasbe
- Year and Model: 02 S60, 98 V70 (EV)
- Has thanked: 31 times
- Been thanked: 79 times
Re: P80 P2 Subframe Bushing installation with pictures 3507923
Check out my 3D Printed Parts for Volvo P2 and P80 on Printables
rombar
- Year and Model: 2002 XC70 2.5T
- Been thanked: 3 times
Hi everyone, I'm new here. Just wanted to thank you both @Blacklab467 and @crasbe for your work guys! I used a mix of both solutions -> fat allen key between subframe and frame, jack to push up and 3D printed tool to make the job easy and protect the bushing. All 4 bushings were fitted super fast. It was actually harder to get old ones off. Thanks guys you're my heroes of the day (week maybe!)
- BlackBart
- Has thanked: 927 times
- Been thanked: 884 times
Funny - I was just looking up this fantastic write-up by Blacklab to assemble tools and things to start this.
- BlackBart
Order of work question -
If replacing the motor mounts at the same time, which should happen first?
- BlackBart
It looks like for the sway bar, you're supporting the engine either with one of those truss lift bars from above or with a wood plank under the pan on a jack, then lowering the subframe to the rear for clearance. This includes loosening the motor mounts and drag link underneath, as well as disconnecting the steering rack so the SF will drop.
So in that scenario, you're doing all that, changing motor mounts, changing the REAR subframe bushings, lifting it back up with a second floor jack and reattaching, seating the rear subframe bushings, then lowering the front of the SF enough to access the front bushings.
whew!
whew!
- Blacklab467
- Year and Model: 2007 xc 70
- Has thanked: 114 times
- Been thanked: 263 times
Do them at the same time, for example do the rear one and the passenger side while you've got the rear subframe dropped. Then do the front and upper one and transmission torque mount while you're doing the front ones. Support the engine with a jack on the oilpan. The engine and subframe doesn't have to drop very far to change any of these parts, at most about 2 inches for the rear engine mount. It'll all become pretty obvious once you get in there. The only caution I would offer is try to minimize the amount you drop the subframe in the vicinity of the steering shaft coupler where it attaches to the rack if you're not going to disconnect it. It is not necessary to disconnect the steering coupler for this job.
2003 XC 70 (sold)
crasbe
Thank you for the feedback and nice words. I like your method!rombar wrote: ↑30 Jun 2025, 10:40 Hi everyone, I'm new here. Just wanted to thank you both @Blacklab467 and @crasbe for your work guys! I used a mix of both solutions -> fat allen key between subframe and frame, jack to push up and 3D printed tool to make the job easy and protect the bushing. All 4 bushings were fitted super fast. It was actually harder to get old ones off. Thanks guys you're my heroes of the day (week maybe!)
Reading stories like this really makes it worth publishing these tools, I was afraid that nobody would have a use for it
- Been thanked: 1002 times
Just thinking what to use as a formed block since I do not have 3D printer. I think a hardwood block could be carved with a router to the required shape.
Can you publish dimensions?
crasbe
Perhaps you can find a volunteer from the US to print you the tool. Shipping it from Germany is quite expensive unfortunately.
But here you have the relevant dimensions:
- BlackBart
I’m not seeing any steel washer to use. Are those on the fronts and I started with the backs?Blacklab467 wrote: ↑19 Dec 2020, 13:13
I used the washer from the first bushing and turned it upside down and glued some top strut nuts on it to make an installation tool and a bushing bolt to fully seat the bushing.
