1996 Volvo 850 GLT N/A - Radiator clips
jragone
- Year and Model: 1996 850 GLT
- Has thanked: 6 times
- Been thanked: 2 times
Does anyone have the part number for the radiator clips into which the bolts that hold the radiator to the condenser mount? There are four that clip on the sides and two on the top. Mine are pretty far gone with rust, so I’d like to replace them.
- Has thanked: 1841 times
- Been thanked: 1710 times
I believe it is #38 the spring nut you are looking for on this drawing. Even expanding the drawing it is hard to see on the left hand of the radiator as seen in the picture.
https://www.volvocarstorontoparts.ca/a/ ... 39909.html
https://www.volvocarstorontoparts.ca/p/ ... 49921.html
Multiple part numbers but this looks like the most recent #: 949921
- Has thanked: 1502 times
- Been thanked: 3813 times
I replace those with M6 hardware in cheap stainless which makes removal a lot less painful.
Zip tie two opposite corners to hold the sand which together, install bolts into other corners, then cut ties and do the first corners.
