Chaosrob 1999 v70R 601 save, Going to need a lot of parts, lot of help and do a lot of reading.. Topic is solved
chaosrob
Year and Model: 1999 v70R
Has thanked: 37 times
Been thanked: 15 times
Re: Chaosrob 1999 v70R 601 save, Going to need a lot of parts, lot of help and do a lot of reading..
Post by chaosrob »
Haven't done much, this week was pretty hectic. I was able to save the original passenger door panel that was water damaged. I think it matches up pretty well and will look good when installed.
I also managed to get a stock complete tank from a donor car in KC. Hopefully I will be able to get the tank into the car this weekend and try to fire it up to better evaluate the mechanical condition
V50M66
Year and Model: 1998 V70 AWD
Has thanked: 26 times
Been thanked: 89 times
Post by V50M66 »
chaosrob wrote: 02 Aug 2025, 06:14 Haven't done much, this week was pretty hectic. I was able to save the original passenger door panel that was water damaged. I think it matches up pretty well and will look good when installed.
Nice, that panel looks good. They’re R specific and far superior to the base car ones where the leather shrinks, so they’re rather rare and expensive to replace.
Donor tank/lines are from a ‘99 or ‘00 I hope? ‘98 uses a different setup since it’s a return-style fuel system as opposed to the returnless system on later cars
1998 V70 AWD - Emerald Green/Tan - M56/Delta link swap, VAST tuned, lots of fun
1998 V70 NA - Nautic Blue/Charcoal - Factory M56/slicktop track car
2006 XC70 Ocean Race - workhorse
2002 S40 1.9T - daily
2004 XC70 - Mystic Silver/Black - former workhorse, parted
2005 V50 T5 M66 FWD - Black Stone/Black leather - former garage queen, sold
chaosrob
Post by chaosrob »
Thank you. Yes, the tank is from a 99 awd, although not an r. I am assuming the fpr is different for an r and regular?
[/quote]
[/quote]
Has thanked: 1497 times
Been thanked: 3809 times
Same fuel pressure regulator for awd and R models, actually even an NA 1999 or 2000 will work.
It takes a small L piece of vacuum hose off aT junction in the evap line to connect to the FPR
chaosrob
Post by chaosrob »
Okay guys, please excuse the mess as I had to move a lot out to squeeze the car in there.
After changing the tank, making a couple of lines , putting fresh oil in it is alive after over 13 years of sitting. I don't have a filter wrench that would fit so I didn't run it long. Any recommendations for a wrench that will fit, my local auto supply didn't have one. TIA
AnotheR ResuRRected!
That 601 looks gReat!
Year and Model: 2001 V70
Has thanked: 927 times
Been thanked: 999 times
Post by volvolugnut »
chaosrob wrote: 02 Aug 2025, 17:38 Okay guys, please excuse the mess as I had to move a lot out to squeeze the car in there.
Assume you are asking about oil filter wrench. I use only the steel band, cam adjustable oil filter wrenches. I have a large and smaller one.
V50M66
Post by V50M66 »
Nice!
This is your guy:
https://www.fcpeuro.com/products/volvo- ... tools-2489
I welcome you both to the Brother/SisterHood of tAWDry Knights of the Round Table. It’s a Scottish thing. I’ve enjoyed reading both your recoveries here and on Swede speed!
chaosrob
Post by chaosrob »
Unfortunately someone cut the cat and flex section of the downpipe off this thing. I have managed to get it running and obviously need to procure a dp or spend the time to fabricate one. I found one with the cat on ebay for 402.00 but like everything on ebay I always question quality, I am posting the link below and if anyone has experience with it I would appreciate hearing from you. The other option I found was from Viva performance, price on theirs is ~1400 and a 6-8 week timeline, quite the investment. Appreciate any advice.
https://www.ebay.com/itm/195120579239?_ ... odel%3AV70
