180K 740 wagon began to start hard on two successive occasions, now it won't start.
It has spark. Is there a quick and dirty way to check for fuel?
I'm wondering if it's a fuel pressure problem. If so, are there two pumps? (one feed and one high pressure) or, is there just one?
I have a generic fuel pressure guage. Where is the fuel port? What should the operating pressure be?
Thanks all for the suggestions!
ignition sparks but won't start. 1990 740 turbo
- billofdurham
- Year and Model: 855, 1995
- Been thanked: 5 times
Before going all technical with ways to check fuel pressure try flicking the fuel pump relay with your finger. It is a fairly common problem on these cars. If it now starts you should replace the relay.
On your car you have an on-board diagnostic unit which you can use to check for any fault codes that have been set.
See: https://www.matthewsvolvosite.com/chat/p ... c&start=12 for location and use. Ignore the heading as it relates to your car as well.
If you are still having problems post back.
Bill.
Bill.
Previously:
1984 244DL, Manual, Beige.
1987 744GLE, Manual, Green.
Previously:
