Apparently there’s a mid-cycle cut-off on 850’s for timing belts. I’ve changed it before but don’t have the order number.
IPD shows a pic of the number stamped on a boss at the rear of the block at the timing belt end. Mine has a heat shield there.
The timing belt cover sticker looks like this -
ARTIKEL NR. 1289853
Is that the engine number, not the rubbed off one below the bar code?
FCP has various cut-off numbers, with 6 digits. Oh, some show 0131155-on with 7 digits.
Verifying Engine Number Topic is solved
- Been thanked: 4071 times
In V70 world
Top one is part number
Second one is serial number
Nice clear picture in my Karla Kat maintenance thread
- BlackBart
- Has thanked: 967 times
- Been thanked: 922 times
So (T) is serial number which I assume is the same as Engine Number, so my lower number on the sticker. ?
- Has thanked: 2205 times
Like you mention, the block is stamped on a flange to the left of the timing cover on a flat flange. Often it is covered in dirt so has to be cleaned to read it. This may help. It should not be covered by the heat shield:
- BlackBart
ah HA! It was black down there, and it's almost under that coolant elbow. A little spray soap and a wire brush and....
- BlackBart
I'm embarrassed - I dug into my 850 folders with receipts and repair info.....and there are the engine numbers etc.
- 1309 Views
Last post by rguzz
- 501 Views
Last post by Oka
- 498 Views
Last post by erikv11
- 6738 Views
Last post by precopster
- 854 Views
Last post by Ozark Lee
