PCV service needed? 99 S70 NA
krenekj
Year and Model: Wife says too many
Has thanked: 2 times
Post by krenekj »
1999 S70 N/A
250k
Owned since new
Last PCV service and new parts at 190k
The latex glove does not inflate, nor does it suck back into the oil filler. I tried this with a few new gloves and even sealed them with a rubber band.
I'm used to seeing it either inflate (needs service) or see negative pressure, but never just sit there.
Is a PCV service needed? Other checks?
Thanks.
93 240 Wagon
99 S70 NA 5sp
02 V70 NA
18 V90CC T5P*
Sveedy
Year and Model: 96 850 Turbo
Has thanked: 445 times
Been thanked: 479 times
Post by Sveedy »
I would say no service needed.
1999 V70 GLT
V50M66
Year and Model: 1998 V70 AWD
Has thanked: 26 times
Been thanked: 94 times
Post by V50M66 »
Service probably needed - if it’s not sucking the glove in, you probably have a leak in the system somewhere. If it wasn’t done using Genuine parts last time, it’s highly likely one or more hoses have disintegrated or cracked and need to be replaced.
Before you start ripping the manifold off to do PCV, check for vacuum leaks or cracked/old lines in both the PCV and intake system.
Oh, and if you do it, genuine Volvo only for parts! The aftermarket crap rarely lasts a year in my experience.
1998 V70 AWD - Emerald Green/Tan - M56/Delta link swap, VAST tuned, lots of fun
1998 V70 NA - Nautic Blue/Charcoal - Factory M56/slicktop track car
2006 XC70 Ocean Race - workhorse
1999 Saab 9-3 - daily
2004 XC70 - former workhorse, parted
2005 V50 T5 M66 FWD - former garage queen, sold
2002 S40 1.9T - former daily, rear ended
krenekj
Post by krenekj »
Thanks for the replies.
I performed the last PCV service using all genuine Volvo parts where I could. The only one I could not replace was the 2-line assembly running under the injector rail. I cleaned that one out and had to find a replacement elbow to connect into the left side of the intake manifold. All the rubber vacuum lines were replaced about the same time using Volvo line.
I could not find any leaks before making my original post, but I suspect that may be the most likely culprit given the PCV was done such a short time ago.
If that's the case, finding and fixing the leak should restore PCV operation. But we'll see.
Thanks again.
93 240 Wagon
99 S70 NA 5sp
02 V70 NA
18 V90CC T5P*
