I'm thinking main bearings were already going and then a valve burnt/dropped causing it to further self destruct. Using regular gas when this happened by chance?
If you want the car to disappear instead of the storage option, just post a listing on craigslist claiming a copy of Epstein's client list (printed on a dot matrix printer using green bar tractor feed paper) is in it...
What killed my S70 T5M... Place your bets
- wizechatmgr
- Has thanked: 45 times
- Been thanked: 129 times
2023 Lexus RZ450e -66k
- WhatAmIDoing
- Has thanked: 104 times
- Been thanked: 105 times
It had 91+ octane in it from a major chain. Also had topped off the oil earlier in the day.wizechatmgr wrote: 04 Feb 2023, 22:11 I'm thinking main bearings were already going and then a valve burnt/dropped causing it to further self destruct. Using regular gas when this happened by chance?
I pulled the dipstick yesterday when I stopped to take the battery. The oil looked suspiciously thin and jet black (basically the opposite of how it looked when I topped it off).
Knows enough to be dangerous
- wizechatmgr
It happen to smell like antifreeze by chance? Or ATF (if auto...)WhatAmIDoing wrote: 05 Feb 2023, 17:58It had 91+ octane in it from a major chain. Also had topped off the oil earlier in the day.wizechatmgr wrote: 04 Feb 2023, 22:11 I'm thinking main bearings were already going and then a valve burnt/dropped causing it to further self destruct. Using regular gas when this happened by chance?
- WhatAmIDoing
Unfortunately, I was (and still am) suffering from a massive sinus infection. Could not smell. I was becoming suspicious of a bad head gasket, but all tests were negative prior to the destruction.wizechatmgr wrote: 08 Feb 2023, 09:13It happen to smell like antifreeze by chance? Or ATF (if auto...)WhatAmIDoing wrote: 05 Feb 2023, 17:58It had 91+ octane in it from a major chain. Also had topped off the oil earlier in the day.wizechatmgr wrote: 04 Feb 2023, 22:11 I'm thinking main bearings were already going and then a valve burnt/dropped causing it to further self destruct. Using regular gas when this happened by chance?
jimmy57
- Has thanked: 5 times
- Been thanked: 322 times
I think rod and/or main bearing major failure is detected with a Fluke test and not a UOI sample. Set meter to ohms and stick it into debris in bottom of pan. 2 ohms or lower is really bad.
- Has thanked: 1613 times
- Been thanked: 4075 times
jimmy57 wrote: 08 Feb 2023, 18:55 I think rod and/or main bearing major failure is detected with a Fluke test and not a UOI sample. Set meter to ohms and stick it into debris in bottom of pan. 2 ohms or lower is really bad.
You are a welcome and huge asset to these pages, jimmy57, and it’s always great to hear from you.
- WhatAmIDoing
I still haven't gotten around to tearing this engine apart. Still trying to get the new engine to run correctly. But I did perform a quick compression test before yanking the old engine. All the cylinders had low compression, but cylinder 3 or 4 (probably 4) had no compression. Stuck a borescope down each cylinder. Lots of carbon build up and cylinder 4 appeared to have lots of scoring. All the plugs had nasty amounts of buildup. Still plan on tearing this apart one day, but for now it looks like catastrophic cylinder failure, possibly broken rings, perhaps caused by a failed rod bearing.
Aren’t the valve guides bronze? Coking and sticking valves will machine the guides and give you golden spiked oil
- 16 Replies
- 3441 Views
Last post by CIK7
- 10 Replies
- 1813 Views
- 23 Replies
- 4015 Views
- 17 Replies
- 4065 Views
Last post by shiloh51933
- 17 Replies
- 4463 Views
Last post by SuperHerman
