I bought a salvage unit. The lense was flapping in the housing and the arm that connects to the plastic stud was broken. I’m hesitant to buy other salvage units for hundreds of dollars to have the same problem.
I can’t pass inspection as is. I have done lots of research and have come up with the following that I want to verify is true before I buy the housings: after I remove the HID harness the halogen lenses should plug in to remaining harness. I will have a bulb out warning but the lights will work.
If I want to remove the bulb warning can I do that with genuine vida/mongoose, or do I need a good DICE clone? Is this something only the dealer can change with my car configuration (selecting halogen.) Or I should be able to? Please, let me know what you think.
