00' V70 X/C SE Mass Air Flow Sensor Replacement With Pics...
2000 V70 MAF Replacement w/ Pics
- sanfelice
- Year and Model: 00 VR;04 XC70;97 965
Another note regarding MAF: I went slightly nuts trying to track a poorly (from slightly to very) running engine a couple years back that kept sending O2 codes. Replaced both O2 sensors, ran fine for a little while, then the same thing happened. Confused, I decided to switch the MAF with another unit i had laying about. Cleaned both MAF wires with CRC cleaner, swapped them back and forth. Only slightly better. Still getting O2 codes, I took it to a shop and the DEALER, who told me that it was the O2 sensor. Not believing them, I just took it back and thought I would do some more research. Finally settled on buying a new MAF. That turned out to be the cause and was apparently pushing codes for the O2 sensor. So, if anyone is getting these symptoms, you may just want to pop for $100 for an aftermarket brand or $225 for the blue box. I ended up buying a Bremi and it's been working for about 8mo. now.
1337
- Year and Model: '18 VW Golf 1.8T 5MT
Amazon has the OEM Bosch MAF for $150. I picked one up a few weeks ago. It even came with free 2-day Prime shipping, fulfilled by Amazon themselves.sanfelice wrote:So, if anyone is getting these symptoms, you may just want to pop for $100 for an aftermarket brand or $225 for the blue box. I ended up buying a Bremi and it's been working for about 8mo. now.
Current: 2018 VW Golf 1.8T Manual
Previous: 1998 V70 T5 Manual, Subaru BRZ, Mini, Miata, etc.
rocky_mtn_man
- Year and Model: XC70 1998
I have found it difficult to remove the air cleaner hose. This forum post suggests removing the air cleaner top and turn th base sideways, to wiggle out the MAF body. I cleaned my old MAF Sensor but we could only drive our 1998 Volvo V7-XC 200 feet before conking out. Maybe I don,t need to remove the hose, just the air box. will try that and post an update.
- Has thanked: 1612 times
- Been thanked: 4075 times
The trick to removing the air cleaner from the snorkel is to tie up the snorkel with strong cord to the upper engine torque mount. That gives you a good pull on the air cleaner body to pop it out of the snorkel tube. Inspect when done, for cracks and breaks. New snorkel tube is about $100 but still available from Mother Volvo
VOlvo makes a special tool for this of course, shown in this thread, must be green...
viewtopic.php?p=277566&hilit=remove+air+cleaner#p277566
In that same thread, ChuckW reminds us the MAF insert can be removed from the plastic housing using Torx security bits and skip all that madness
- Has thanked: 2212 times
- Been thanked: 1853 times
I just recently bought a set of 5 point Torx bits for this job. Way easier to swap without having to remove the whole unit!
- 2504 Views
- 9361 Views
Last post by jonesg
- 13 Replies
- 10485 Views
Last post by jimmy57
- 974 Views
Last post by tamtam2122
- 1227 Views
Last post by jasontindal
