850 washer bottle?
454cid
Year and Model: 1996 850
Has thanked: 151 times
Been thanked: 139 times
Post by 454cid »
Yesterday, I tried pumping out the windshield washer fluid bottle. I'm trying to remove fluid that will freeze if the temp gets too low. I ran into a problem in that the hose won't pass through from the filler neck into the bottle itself. Looking inside, it looks like the plastic is collapsed.... it's hard to see, so I'm not 100% sure what I'm looking at, but a hose won't pass through.
Anyone had the bottle out of the car, and examined it up close? I was simply going to order another one, but it seems they aren't available new, even in the aftermarket.
Removal is though the wheel well correct?
1996 850
2010 Ford Focus SE
2006 Cadillac CTS
1996 Mercedes C220
1999 Chevrolet K3500
1969 Buick LeSabre Custom 400
Has thanked: 2215 times
Been thanked: 1853 times
Yes to the 2nd question. Can you post a picture to jog my memory? Apologies, can't recall if this is a wagon or sedan.
454cid
Post by 454cid »
scot850 wrote: 11 Oct 2025, 08:36 Yes to the 2nd question. Can you post a picture to jog my memory? Apologies, can't recall if this is a wagon or sedan.
This is a sedan. No wagons here yet.
Picture of what, to me, looks like collapsed plastic? I'll try.
1996 850
2010 Ford Focus SE
2006 Cadillac CTS
1996 Mercedes C220
matthew1
Site Admin
Year and Model: 850 T5, 1997
Has thanked: 2866 times
Been thanked: 1332 times
Post by matthew1 »
454cid wrote: 11 Oct 2025, 08:23 Yesterday, I tried pumping out the windshield washer fluid bottle. I'm trying to remove fluid that will freeze if the temp gets too low.
You could activate the windshield washers until it's dry.
Also -> Amazon link
Pull one of the pipes off the bottom of the tank and run it dry like Matthew suggests. In the 'old' days we used to add methylated spirits to to the washer bottle fluid to stop the water freezing!
Has thanked: 312 times
Been thanked: 818 times
The "no freeze" washer fluid has methanol in it - same approach.
Has thanked: 1613 times
Been thanked: 4077 times
I think the filler neck has a cheese grater filter on it to stop leaves from clogging the pump.
Pop off one of the lines from the nozzles carefully ( maybe even cut with a knife if you have slack) and it will pump out quickly. Then fill with Orange or blue stuff.
454cid
Post by 454cid »
Thanks for the tips. I didn't get back to this yesterday, as I was trying my hand at plugging a tire.... still leaks, but not as fast, so I guess that's better?
1996 850
2010 Ford Focus SE
2006 Cadillac CTS
1996 Mercedes C220
