I spoke too soon. The ball joint is ever so slightly leaking now. Third time under the car is a charm eh.
Edit: not sure, but don’t feel any airflow out the ball joint anymore. Seems the flared pipe got a bit crooked during clamping.
I pulled as hard as I could to seat the flared end into the ball joint end, but this was all I could push into.
Chieber
- Year and Model: 1998 v70
- Has thanked: 45 times
- Been thanked: 29 times
The drone around 2k rpm is too unbearable for me. After a ride, my ears are hurting.
I’ll install the original muffler again when I have the time for it and try to sell the ferrita.
Thanks for all your advice.
1/2 a shitbox V70 1998 2.5 NA
- rolsen11
- Year and Model: 2000 V70 SE
- Has thanked: 19 times
- Been thanked: 22 times
I didn't make a post yesterday, but I got the job completed. I'm a novice at this stuff so I took my sweet time making sure I did everything correctly and with quality.
-New timing belt + tensioner and idler
-New water pump
-New serpentine belt
-New coolant reservoir and level sensor + coolant flush and change as a byproduct
What's next now? I think I mentioned that I need a new serpentine belt tensioner pulley. I need to order some winter tires to put on the old 15" rims my car came with. I also have a box full of parts I have yet to install... I suppose I should do that next lol
-New water pump
2000 V70 SE - Bought sight unseen in Cleveland, currently my only car. Looks identical to my profile picture
- 850 LPT
- Year and Model: 96' 850
- Has thanked: 331 times
- Been thanked: 242 times
Mine is actually a very generic ANSA exhaust, nothing fancy. It's just a tad louder than the original but still has the typical P80 sound.Chieber wrote: ↑03 Nov 2025, 10:10There’s a oval tailpipe from Simon’s that seems to be 23cm long. This one is only 18cm. So without messing with the exhaust again, I think I’ll try the longer tailpipe first.
How is the sound of your exhaust? I’m kind of disappointed in the ferrita cat back.
With the oem exhaust I had this nice 5 cilinder sound in the cabin.
Now it’s too much bass and droney around 2krpm.
58' Porsche Diesel Junior
13' Honda Odyssey
13' Honda Odyssey
- DennisCA
- Year and Model: 1996 850
- Been thanked: 59 times
Minnesota I assume is a place what salts its roads, so my suggestion is hose down the undercarriage in some thin and penetrating oil, then after it's dried do woolwax or similar over it.rolsen11 wrote: ↑03 Nov 2025, 16:34 I didn't make a post yesterday, but I got the job completed. I'm a novice at this stuff so I took my sweet time making sure I did everything correctly and with quality.
-New water pump
Chieber
That’s what I want in the sound. Little bit louder but without the bass.850 LPT wrote: ↑03 Nov 2025, 17:48Mine is actually a very generic ANSA exhaust, nothing fancy. It's just a tad louder than the original but still has the typical P80 sound.Chieber wrote: ↑03 Nov 2025, 10:10There’s a oval tailpipe from Simon’s that seems to be 23cm long. This one is only 18cm. So without messing with the exhaust again, I think I’ll try the longer tailpipe first.
Do you have the part nr for that exhaust? I can’t find an exhaust for the Volvo. Maybe it’s out of production.
- 850 LPT
So I was wrong, it was a Starla brand exhaust. This is the one I used on 2 of my S70's, but it looks like it is not available right now.Chieber wrote: ↑04 Nov 2025, 07:55That’s what I want in the sound. Little bit louder but without the bass.850 LPT wrote: ↑03 Nov 2025, 17:48Mine is actually a very generic ANSA exhaust, nothing fancy. It's just a tad louder than the original but still has the typical P80 sound.Chieber wrote: ↑03 Nov 2025, 10:10
But that might be different in Europe, I don't know.
https://www.fcpeuro.com/products/volvo- ... 70-290-517
13' Honda Odyssey
13' Honda Odyssey
- rolsen11
Indeed it is. I make a point to wash the undercarriage regularly during the winter using the automatic car washes in town. I haven't tried any undercoating yet, not sure if I will on this car tbh. It's already a little crusty underneath since it was a New Jersey and an Ohio car before I bought it. I'm probably just going to continue washing it and driving it until the car is completely worn out. There's no vehicle inspection of any kind in Minnesota so I don't need to worry too much. I will need to do a handful of rust repairs in the future though. The rear exhaust hangar just rusted off so now it looks a little limp back there
- Has thanked: 1836 times
- Been thanked: 1709 times
It might be worth looking at using Fluid Film protectant. It comes in clear and black, aerosol or 1 gallon can.
I takes a bit of work but will slow down the decay considerably. May need to recoat every couple of years in worst areas.
- jreed
- Has thanked: 352 times
- Been thanked: 192 times
I checked the tightness of the hose clamps on the short turbo outlet hose (9179002) using a new tool... a 12pt 7mm swivel socket wrench. This little guy fits into the tight spots:
