Vida CEM swapping
dikidera
Year and Model: S60 2005
Has thanked: 68 times
Been thanked: 187 times
Post by dikidera »
What vehicle profile did you select? Also go in App Logs and see if anything was written there.
gavik
Year and Model: 2006 xc90
Has thanked: 21 times
Post by gavik »
dikidera wrote: 14 Dec 2025, 13:56 What vehicle profile did you select? Also go in App Logs and see if anything was written there.
There is also no way to edit the profile, the edit profile button does not work, and the vin decoder does not work
dikidera
Post by dikidera »
Thanks for this, I will begin investigating now, because I personally didnt get these issues with my own profile. For sure there is some error in the logic. The profile builder will work though.
dikidera
Post by dikidera »
Please test this new version. It should have fixed the issues, but most importantly, verify when the parts catalog loads that its data is 1:1 with the real vida. What is weird in your screenshot is that the vehicle shows 5 profiles, but on my android-vida I only get 3. What region is that?
android-vida_fix.zip
(10.61 MiB) Downloaded 17 times
gavik
Post by gavik »
dikidera wrote: 17 Dec 2025, 10:05 Please test this new version. It should have fixed the issues, but most importantly, verify when the parts catalog loads that its data is 1:1 with the real vida. What is weird in your screenshot is that the vehicle shows 5 profiles, but on my android-vida I only get 3. What region is that?
I'll try to check in a few days, as I don't have access to a computer right now to build the APK.
S40cem
Year and Model: 2006 s40
Post by S40cem »
Hello everyone. I have a 2006 Volvo S40. I’m trying to find the PIN code for my CEM module: 30728906, “I am using the program code from this link:https://github.com/vtl/volvo-cem-cracke ... me-ov-file But unfortunately, the code cannot be found.Could you please advise what other options are available?
vtl
Year and Model: 2005 XC70
Has thanked: 130 times
Been thanked: 686 times
Post by vtl »
S40cem wrote: 19 Dec 2025, 06:56 Hello everyone. I have a 2006 Volvo S40. I’m trying to find the PIN code for my CEM module: 30728906, “I am using the program code from this link:https://github.com/vtl/volvo-cem-cracke ... me-ov-file But unfortunately, the code cannot be found.Could you please advise what other options are available?
Assuming the cracker hw works and can make progress, it is just pin that fails to be found... Try this version, it works better for P1 CEMs: https://github.com/cmolson/volvo-cem-cr ... e/one_pass
If it still fails, try to change the shuffle order for your CEM p/n, last digit in this line: https://github.com/vtl/volvo-cem-cracke ... er.ino#L82 Four shuffle orders are available, 0 to 3.
S40cem
Post by S40cem »
Thank you very much for your reply.
I tried different order settings from 0 to 4, but every time the software reported that the PIN code could not be cracked. Each attempt produced a different 6-digit result.
vtl
Post by vtl »
S40cem wrote: 19 Dec 2025, 08:05 Thank you very much for your reply.
Try to remove this line: https://github.com/vtl/volvo-cem-cracke ... .ino#L1322 (and similar line in one_pass branch, try it there, too). Also show a good picture of your hardware?
S40cem
Post by S40cem »
