no tach, no gear indicator, then went away
hu5ker555
Year and Model: 2008 S60, 2015 S60
Has thanked: 46 times
Been thanked: 18 times
Post by hu5ker555 »
2008 S60 2.5T 252k
Last week all of a sudden while driving, the tachometer shut down, my gear indicator was " - ", and the car just felt weird. Shifted strange, sounded off. All kinds of codes popped up.
Turned it off, let it sit for a while, cleared all codes, and it's been running fine ever since.
Anyone experienced something like this before?
ignatz
Year and Model: 2006 S60 t5m
Has thanked: 18 times
Been thanked: 33 times
Post by ignatz »
Do you remember the codes? It might point to something that something that controls the tach, gear indicator and wonky shifting. You might get lucky and never see this problem again. I would not be so lucky.
2002 V70 2.4
2005 S60 2.5t awd
2006 S60 t5 stick shift
Year and Model: 2001 V70
Has thanked: 987 times
Been thanked: 1078 times
Post by volvolugnut »
Perhaps a momentary loss of electric power from a bad connection?
Has thanked: 2210 times
Been thanked: 1852 times
Speed signal/ABS signal issue? If you did not lose the speed indication then that would be unlikely I think on the ABS, but it could still be a peed signal to the trans.
EngineeringBloke
Year and Model: 2006 2.5T S60
Has thanked: 57 times
Been thanked: 39 times
Post by EngineeringBloke »
I had a few years when I'd get an intermittent transmission fault. The display would loose the 'D', replaced by a '-'. I'd get a check engine warning light, and my odb2 would report transmission control unit communications failure. The car would feel like it was in too high a gear, lacking in power.
This sometimes happened after highway driven and encountering heavy traffic. I don't recall the transmission temperature but it might have been elevated.
However, it was often gone on restart.
I suspected a connection issue in the TCM. So I bought a tool to release the TCM from its base and used electrical contact cleaner. I checked the tiny fan that vents the ECM/TCM box but it seemed ok.
I've not had the problem for 5 years or so now.
I don't think I had issues with the tach but that could still come from the TCM.
Been thanked: 504 times
Post by cn90 »
Could be bad instrument cluster.
hu5ker555
Post by hu5ker555 »
EngineeringBloke wrote: 19 Dec 2025, 17:32 I had a few years when I'd get an intermittent transmission fault. The display would loose the 'D', replaced by a '-'. I'd get a check engine warning light, and my odb2 would report transmission control unit communications failure. The car would feel like it was in too high a gear, lacking in power.
That sounds similar, though i lost the tach. The issue has not come back, but I guess I might try your suggestion if it does. Thank you!
DavidE7
Year and Model: 01-07 V70, S60, XC70
Has thanked: 67 times
Been thanked: 93 times
Post by DavidE7 »
I had that problem when the radiator was leaking coolant into the transmssion fluid. It stopped happening after I replaced the radiator and drained/flushed the transmission. The transmission fluid had turned brown from the mixing of the blue-green coolant with the red transmission fluid.
David E
2001 Moondust V70 2.4 293,000 miles
2001 Nautic Blue V70 2.4 231,000 miles
2004 Nautic Blue XC70 2.5T 258,000 miles
new: 2004 Black Saphire V70R 193,000 miles
2007 Titanium S60 2.5T 277,000 miles
2007 Magic Blue S60 2.5T 233,000 miles
2007 Silver V70 2.4 203,000 miles
P2 Volvos for every person in my family
