Krons
Has thanked: 193 times
Been thanked: 202 times
Post by Krons »
br0dy519 wrote: 19 Jan 2026, 11:35 Biggest problem in your list is the wheel sensor. Likely a $10 tone ring or you could replace the full CV.
Problem solved today. Turns out the TRQ CV shafts I installed are not tapped as deep as the originals. So when I torqued the shaft bolts at the wheel hub they were bottoming out, allowing the shaft to slide back about 1 cm — just far enough the sensor was not picking up the tone wheel. Ugh. I had checked bolt torque but never gave the shaft a pull for any slack…
Interesting the CV shafts were put in 5000 miles ago and this just cropped up. They do not come with bolts so I reused the old ones. Shorter 10.9 flanged bolts from my farm supply store 2 miles away and it is sorted.
I also identified my liftgate root cause. Cable that attaches to the latch mechanism was broke so $85 eBay replacement on order.
A spare key is most painful…covered here on the forum ad nauseam…$440 for a fob or $113 for a valet key PLUS $224 to program either one. With an AirTag on the only functional key I may roll the dice. Just can’t swallow $337 for a spare key on a $1500 vehicle.
08 C702.5T (sold)
The non-Swedes:
br0dy519
Year and Model: 2004 XC70
Has thanked: 126 times
Been thanked: 116 times
Post by br0dy519 »
Nice work. Looks like you will remain one of us. One of us. One of us....
Are those fob prices the yagger price? Or dealership? I believe it was closer to half that to have it done remotely by him.
04s60 2.4
04xc70 2.5t
vtl
Year and Model: 2005 XC70
Has thanked: 114 times
Been thanked: 606 times
Post by vtl »
Krons wrote: 19 Jan 2026, 19:20 A spare key is most painful…covered here on the forum ad nauseam…$440 for a fob or $113 for a valet key PLUS $224 to program either one. With an AirTag on the only functional key I may roll the dice. Just can’t swallow $337 for a spare key on a $1500 vehicle.
Break the ignition lock, so it accepts even a screwdriver. Glue your the only remaining key to immobilizer antenna. This is what I did years ago.
br0dy519
Post by br0dy519 »
vtl wrote: 20 Jan 2026, 06:56
You have my attention. Any threads with the info? I will have to search it up. Good info to have to get out of a jam potentially in the future.
04s60 2.4
04xc70 2.5t
vtl
Post by vtl »
br0dy519 wrote: 20 Jan 2026, 09:32 You have my attention. Any threads with the info? I will have to search it up. Good info to have to get out of a jam potentially in the future.
Disassemble the lock, toss the steering column lock into trash bin, grind the tumblers off, assemble back.
You need either a Dremel with cutting disk almost worn out to do a flat screwdriver slot in two shear bolts in order to unbolt the lock. Some folks were able to use a punch, but Dremel is easier/faster.
Krons
Post by Krons »
br0dy519 wrote: 20 Jan 2026, 06:46 Nice work. Looks like you will remain one of us. One of us. One of us....
Dealer prices.
08 C702.5T (sold)
The non-Swedes:
Krons
Post by Krons »
How do you ensure it doesn’t get stolen? Or is the strategy to put full coverage on it and hope that it does?
:lol:
08 C702.5T (sold)
The non-Swedes:
vtl
Post by vtl »
Krons wrote: 20 Jan 2026, 19:15 How do you ensure it doesn’t get stolen? Or is the strategy to put full coverage on it and hope that it does?
:lol:
Steal what? A 20 years old foreign car that is not known for reliability or any remaining resale value? :)
Year and Model: 2001 V70
Has thanked: 927 times
Been thanked: 1000 times
Post by volvolugnut »
As far as any potential thief knows, you locked the door and the car has fully active steering lock system that came with it new.
volvolugnut.
matthew1
Site Admin
Year and Model: 850 T5, 1997
Has thanked: 2656 times
Been thanked: 1248 times
Post by matthew1 »
This reminds me of Volvo's radio codes and the thousands of hours of aggregate owners' wasted time in the last 30 years trying to find codes. Who is going to steal a double-din factory radio?! No matter how good they sound, they're DOUBLE DIN.
Also -> Amazon link
