No tachometer and spedometer 1998 Volvo S70 Topic is solved
WinDVD
- Year and Model: 1998 Volvo S70 Base
- Has thanked: 26 times
- Been thanked: 6 times
If this is the case then previous owner must have swapped the cluster in from a 99, how does one tell the difference between 98 and 99 cluster? This car is certainly a 98, it has no key chip immobilizer and the vin is 98 also.
- xanthefin
- Year and Model: 1997 850
- Has thanked: 106 times
- Been thanked: 130 times
MCU and other things on board. Maybe its Frankenstein aka swapped then.
Outside only by P/N i would say quickly as they so similar honestly.
WinDVD
These are part numbers on cluster, it's possible previous owner tried to swap broken cluster with this one maybe?xanthefin wrote: ↑23 Feb 2026, 15:41MCU and other things on board. Maybe its Frankenstein aka swapped then.
9451531 and 9168144
- Has thanked: 1506 times
- Been thanked: 3819 times
All the chip dates support a 1998 build ? Isn’t 1998 v70 early CANBYS?
On edit…No CANBUS in 1998
Corrected above. 1998is not CANBUS
WinDVD
I've gone ahead and purchased a proper 98 cluster, hopefully will solve the woes lol. The cluster being the wrong one makes me wonder what the real mileage is on this car lol
- 633 Views
Last post by deedatc
- 1778 Views
Last post by esl_97_850_T5
