jonesg wrote: 05 Feb 2026, 21:07next step would be to test wiring continuity at pem to the plug at the pump.smokedlights wrote: 04 Feb 2026, 08:43car has 220k miles.. dont care about relocation just need to get it started.. ordered 2 pem from ebay one new one used.. neither made it start.. only time it starts if it i put a battery to the fuel pump via the PEM plug..jonesg wrote: 04 Feb 2026, 03:35 its advisable to order the PEM adapter harness from FCP and relocate the PEM to the spare tire area.
Grab another used PEM on ebay.
Pem should see continuous 12v feed, its ground side switched via CEM?
You'd have to look at the circuit diagram to trace the signal wire.
You didn't give enough information to track the wiring diagram but you can do it easy enough, its all here.
https://charm.li/Volvo/2004/
PEM has been verified to get 12v as soon as you crank the key.. who knows if its continuous because car dont start lol wire from the PEM to the pump should be solid since I use the actual PEM plug to power the fuel pump (then it runs and starts) Id assume since PEM sees power CEM and all other relays are fine? unless you can think of something else. Car is 2004 S60.. vin 64 non turbo
