You can save. It's the second option under open file.Dudde wrote: ↑14 Feb 2026, 11:48For remote programming you don't need to touch CEM (only if you going to add another transponder aswell).poteroa wrote: ↑14 Feb 2026, 11:15 Hi all.
Quite massive page count on this topic..
Have a question, and maybe someone can answer directly without need to go through 430 pages
Just read the CEM on a V70, 2001 and looking for the PIN. (And IMMO code of course if it is possible to decode from there)
I used the kaev´s Arduino BDM soft, the only problem is that you can not save the read binary with that software.
https://volvo-tech.com/en/793-2/ (Used Arduino UNO for this, as it was easily available).
Going through the peoples replys, I found info that the PIN should be located in address 0x04E000 is this right?
Do not see any sense to buy expensive programmer just for getting one remote programmed to otherwise cheap car.
Anyone able to help on this?
Oh, the CEM unit is HW-PN: 9452596
Other markings: 8645697/01W075
And for saving the bin just use copy paste
CEM pin 0x4000 or 0x6000
Vida CEM swapping
buruss
- Year and Model: 2002 s80
- Has thanked: 3 times
Re: Vida CEM swapping
Hi all, thank you for this wonderful project! Some months ago I bought a 2010 S40 2.4i, and I am looking for some help setting up my own device, as I have some trouble connecting to the vehicle. As I am not familiar with either programming or electronics, I asked one of my friends to assembly a CEM pin cracker based on the documentation found at GitHub. However, when I try to run the program, it says at the end: "Unknown CEM part number 0. Don't know what to do. Resetting all ECUs." I understand that it refers to the lack of CAN bus connection. Could you please help us identify what went wrong during assembly? I made some photos of the device as is. Thank you very much for your insights.
vtl
- Year and Model: 2005 XC70
- Has thanked: 114 times
- Been thanked: 606 times
Do you see any CAN messages running?Rubie wrote: ↑02 Mar 2026, 06:17 Hi all, thank you for this wonderful project! Some months ago I bought a 2010 S40 2.4i, and I am looking for some help setting up my own device, as I have some trouble connecting to the vehicle. As I am not familiar with either programming or electronics, I asked one of my friends to assembly a CEM pin cracker based on the documentation found at GitHub. However, when I try to run the program, it says at the end: "Unknown CEM part number 0. Don't know what to do. Resetting all ECUs." I understand that it refers to the lack of CAN bus connection. Could you please help us identify what went wrong during assembly? I made some photos of the device as is. Thank you very much for your insights.
It is something like here in the picture. I will shortly run a test, and copy the output of the serial monitor.vtl wrote: ↑02 Mar 2026, 06:24Do you see any CAN messages running?Rubie wrote: ↑02 Mar 2026, 06:17 Hi all, thank you for this wonderful project! Some months ago I bought a 2010 S40 2.4i, and I am looking for some help setting up my own device, as I have some trouble connecting to the vehicle. As I am not familiar with either programming or electronics, I asked one of my friends to assembly a CEM pin cracker based on the documentation found at GitHub. However, when I try to run the program, it says at the end: "Unknown CEM part number 0. Don't know what to do. Resetting all ECUs." I understand that it refers to the lack of CAN bus connection. Could you please help us identify what went wrong during assembly? I made some photos of the device as is. Thank you very much for your insights.
vtl
These all are send requests sent by Teensy to car. Teensy does not get any messages from the car.
You can try to remove autodetect: https://github.com/vtl/volvo-cem-cracke ... er.ino#L14 If that will not help - check your device.
Thank you very much for the tips, I will try them in the coming days!vtl wrote: ↑02 Mar 2026, 09:27These all are send requests sent by Teensy to car. Teensy does not get any messages from the car.
Hello everybody,
I have registered me at "Matthews" because of getting an 2005 Volvo V70 2nd Generation; so the step to tune up "my" Volvo was not far away; now I´m here and, of course, I´m impressed and thankfull about provided information and know-how.
I have build my own "CEM-Cracker" for further diagnostics, for e.g. coding new keys and so on.....
The result after a "few" hours.....
Many thanks to whom created such a powerfull tool !!!
Many thanks and a nice day
Greetings alex3211
Greetings alex3211
vtl
14 hours? On a 500 Kbps CAN bus? It usually takes 20 to 40 minutes.alex3211 wrote: ↑Yesterday, 04:14 Hello everybody,
Greetings alex3211
Hello vtl,
maybe its founded in my soldering-skills and/or board-wiring.....the cem-cracker software has calculated 2 bytes only; four bytes where identified by brute- force.....so for the first time and finally with success.... I'm satisfied
Nice day
alex3211
Nice day
alex3211
- 6431 Views
Last post by RickHaleParker
- 8699 Views
Last post by forumoto
