V70 P2 PCV breather hose replacement on a non-turbo engine
- br0dy519
- Year and Model: 2004 XC70
- Has thanked: 132 times
- Been thanked: 126 times
Is that an LPG vehicle?
04s60 2.4
04xc70 2.5t
04xc70 2.5t
- DavidE7
- Year and Model: 01-07 V70, S60, XC70
- Has thanked: 67 times
- Been thanked: 94 times
Remove the fat rubber hose between the air filter housing/mass airflow sensor and the electronic throttle. There will be very limited visibility but enough space to feel what you are doing. Your visibility is extra limited by the LPG components blocking the small view spaces between the 5 intake pipes of the manifold. As explained in a prior post, removing the throttle body also helps increase clearance and allows you an opportunity to clean the buildup of oil and carbon which usually improves idle smoothness.
David E
2001 Moondust V70 2.4 293,000 miles
2001 Nautic Blue V70 2.4 231,000 miles
2004 Nautic Blue XC70 2.5T 258,000 miles
new: 2004 Black Saphire V70R 193,000 miles
2007 Titanium S60 2.5T 277,000 miles
2007 Magic Blue S60 2.5T 233,000 miles
2007 Silver V70 2.4 203,000 miles
P2 Volvos for every person in my family
So replaced the hose today, did have to remove the inlet manifold as there was no way that you could remove the clamp on top of the oil trap. After replacement did the glove test and there is a slight vacuüm so thats good. I do have a slight whining noise now which stops when removing the dipstick or oil cap. Do I have to dig in again and replace the oil trap due to a possible stuck membrame?
chrism
- Year and Model: S80 / 2005
- Has thanked: 7 times
- Been thanked: 89 times
Yep, most likely. The diaphragm gets all coked up and ruptured and won’t function as intended. That subjects the crankcase to more vacuum than normal, hence the whistling noise.Lordflash wrote: 12 Apr 2026, 14:23 Do I have to dig in again and replace the oil trap due to a possible stuck membrame?
Years ago I cut one open and posted a photo of the inside - hit the link below.
download/file.php?id=69659
- br0dy519
Please replace the banjo bolt while you're in there!! Many threads on this issue describing catastrophic damage with a poor obsolete design in early years.
04s60 2.4
04xc70 2.5t
04xc70 2.5t
- br0dy519
My bad.. yes it appears yours doesn't have it nor a coolant line from the thermostat. I swear I did the replacement on my 2.4 ...
04s60 2.4
04xc70 2.5t
04xc70 2.5t
- 1176 Views
- 268 Views
Last post by Ragman
- 1367 Views
Last post by Sisujoel
- 1864 Views
Last post by chaseinger
- 42 Replies
- 9339 Views
Last post by firstv70volvo
