1998 v70xc 5cyl turbo here.
so, i'm doing a big service this weekend. belts and water pump plus the PCV system. got the PCV kit from FCPeuro.
https://www.fcpeuro.com/products/volvo- ... bo-850t200
but there's a hose coming into (or out of, what do i know) the intake manifold on the passenger side, it sits right underneath the thermostat. that hose is fully broken off (see pic), and i'm not entirely positive this part comes with the above kit.
i just don't want to start digging into what is my daily driver just to find out i'll need another part. any pointers as to what part number that little bugger is would be highly appreciated.
thanks all!
PCV breather question Topic is solved
- chaseinger
- Year and Model: V70 XC 1998
previous:
740 GL sedan in that hideous light green metallic
740 GLT station wagon (sold, but still alive with 600k+ miles)
760 GLE sedan grey metallic
current:
1998 V70XC (AWD, well, not anymore)
current:
Sommerfeldt
- Year and Model: 2018 S90 T8
- Has thanked: 55 times
- Been thanked: 42 times
You can see that hose in the first picture of the kit - it's the longer, skinnier one with elbows at either end that's bundled with the thicker one in the foam sleeve.
- S
- S
[Sold] '97 S70 T5
[Sold] '97 S70 T5
- chaseinger
excellent, thanks! with my previous experience with FCPeuro i assumed it's all there, just wanted to be sure.
previous:
current:
current:
- Been thanked: 504 times
Over the years, I found the PCV kit not to be useful b/c the only things I needed were:
- Hose from Oil Trap ---> Valve Cover.
- Short hoses x2 between Oil Trap and Engine Block.
and that is about it.
I went through this before. I didn't use the plastic vent pipe, which itself does not last too long.
I did the 5-8-inch hose mod 4 years ago, so far so good.
If you clean the oil trap, you can re-use it. Most people here re-use the oil trap.
Here is the 5/8-inch hose mod:
https://www.matthewsvolvosite.com/forums ... hp?t=53448
- Clemens
- Has thanked: 498 times
- Been thanked: 228 times
+1 on the 5/8 hose mod. I had to redo everything because with the plastic pipe i didn't get enough vacum.
1996 855 R,
2010 V70 D5,
2010 V70 D5,
- Has thanked: 311 times
- Been thanked: 817 times
If you want to go with the 5/8 hose method consider dong it this way, MVS member tryingbe has really figured out the way to go:
https://www.matthewsvolvosite.com/forums ... =1&t=77278
- chaseinger
it was a good thing i bought the kit, because it either was neglected by previous owners or it was redone with the cheap-o uro stuff. the main line had cracked on 3 points, the small one going into the intake manifold broke right off the nipple, all brittle and super gunked up.
i heard of the bigger tube method but concur that the hole in the needle is the PTC, which is cleaned now too.
so all good there, just busted a nut on the intake manifold when re-installing. which is a whole different story: https://www.matthewsvolvosite.com/forums ... =1&t=79456
previous:
current:
current:
- 42 Replies
- 9091 Views
Last post by firstv70volvo
- 4690 Views
Last post by jamadams11
- 122 Replies
- 17423 Views
Last post by jonesg
- 910 Views
Last post by ggleavitt
- 13 Replies
- 3287 Views
Last post by nickbw898
