Broken Lumbar Support, Driver's Seat Topic is solved
How to Fix Lumbar Support on a Volvo S60 Seat
- DavidE7
- Year and Model: 01-07 V70, S60, XC70
- Has thanked: 67 times
- Been thanked: 93 times
Matthew's Volvo Site has helped fix many problems with my fleet of P2 Volvos! This topic inspired a slightly different solution. Attached are a couple pictures of the fix that I used for attaching replacement hooks to the end of the lumbar cables. Both cable ends were broken on my 2007 S60. The goal was to keep the new hook in almost the exact same location at the zinc cast hook so the cable tension knob would still provide adequate lumbar support. I used the same U clamp as in the prior solutions but added an eyebolt that was bent open just enough to hook around the seat frame. I added two nuts that were locked onto each other as a stop to keep the U clamp from sliding off in event of a rear impact collision. The hardware was picked up at Lowes for a few dollars.
David E
2001 Moondust V70 2.4 293,000 miles
2001 Nautic Blue V70 2.4 231,000 miles
2004 Nautic Blue XC70 2.5T 258,000 miles
new: 2004 Black Saphire V70R 193,000 miles
2007 Titanium S60 2.5T 277,000 miles
2007 Magic Blue S60 2.5T 233,000 miles
2007 Silver V70 2.4 203,000 miles
P2 Volvos for every person in my family
- Bachadaboy
- Year and Model: 2010 XC60 T6
- Has thanked: 6 times
- Been thanked: 5 times
If you want a quick solution, and you have a Dremel, just cut slices in the seat frame near the holes on both sides of the seat frame. Pry apart the metal just enough to get the cable through, insert the cables and bend the metal back. You will need to pull the lumbar mesh frame about 5-10 mm closer towards the holes to make the shorter cable reach and slide into the hole, which means you'll never zero tension like when it was broken, or when the knob was screwed all the way out.
But it does mean you now get maximum lumbar support, more than you could from factory. Good thing with this method is there's no need to buy anything from the store and the whole repair took about an hour.
I used zip ties instead of hog rings on the seat back.
Ironically after I repaired the function to the lumbar support I liked the knob totally unscrewed (i.e. just a tad more lumbar support than the broken setting) I guess I got used to it like that and now any added lumbar support feels weird. But the good thing is it works now and I'm happy I can adjust it if I want.
"My Volvo is like a mistress. She always gives me something to worry about, but I still love her anyway."
- 1911 Views
- 1543 Views
Last post by RickHaleParker
- 791 Views
Last post by GR8RDane
- 674 Views
Last post by oragex
- 10 Replies
- 2505 Views
Last post by caltemus
