jsrnsis
Year and Model: P80 enjoyer
Has thanked: 25 times
Been thanked: 71 times
Post by jsrnsis »
rolsen11 wrote: 03 May 2026, 14:23 Since the weather finally got really nice, I changed my out my winter wheels: 20260503_130215.jpg
Very clean alloy wheels, I'm jealous.
1998 V70XC black 215xxx
2014 S80 T6 AWD 110xxx
1998 V70XC nautic blue 155xxx
2024 Honda CRF110F
Previous Volvos:
1997 850 GLT 239,577
1998 V70 NA silver 202,510
1994 850 NA gray 125,000
1998 V70 NA white 163xxx
1997 850 GLT 125xxx
jsrnsis
Post by jsrnsis »
abscate wrote: 02 May 2026, 12:17 If you have the air pump sometimes you hear fuel firing in the exhaust which sounds like a misfire. It ends in 28 seconds
I think you mean the rusty water indirect-injection system interface manifold.
Perfect place to mount the compressor for a train horn though.
2024 Honda CRF110F
Previous Volvos:
1997 850 GLT 125xxx
rudsaki
Year and Model: 1998 S70 T5
Has thanked: 29 times
Been thanked: 16 times
Post by rudsaki »
Went crazy on last rattle.
Cut this mount out where the end of the console goes in S70.
Worked!
Previous Volvos
1969 142s Blue manual.
1966 122s Yellow with the 69 motor in it
1971 144s Red . Also the '69's motor
1973 P1800ES Aqua Manual with OD.
1971 142E Light Blue manual with OD.
1979 244DL Brown manual. Marriage/baby car. Divorce, Ex got it and sold it to my father!
1968 1800s White manual/OD. Strong runner. Killed by a '66 T-Bird
1984 242 Turbo Intercooler Silver Manual/OD
1966 1800s White Manual/OD
1985 740 Turbo Intercooler Silver Manual/OD Sold to Nephew
Chieber
Year and Model: 1998 v70
Has thanked: 69 times
Been thanked: 49 times
Post by Chieber »
Went to my beloved pnp junkyard.
I love it, but also hate it.
Whyyyy would you tear up all the door panels that are perfectly fine.
Also, I don’t like forklifts. They keep bending the braces under the c70’s.
1/2 a shitbox V70 1998 2.5 NA
brunocerous
Year and Model: 1998 V70
Has thanked: 303 times
Been thanked: 43 times
Post by brunocerous »
One of my kids actually requested a ride in Blue Steel today because we needed to fit his friend’s mountain bike in the back. I was so proud!
Unfortunately, the ABS once again started acting up as it had over the past week. Today, the ABS light came on, even though I’d gotten one of the refurbished ones. Is there something I should check before reaching out to the company?
1998 V70 T5, AT, project
2004 XC90 AWD (sold)
1999 V70 XC AWD, AT (RIP)
1998 S70 T5, AT (RIP)
Chuck W
Year and Model: 97 854 T5
Has thanked: 97 times
Been thanked: 340 times
Post by Chuck W »
Seeing as my wife keeps killing tires on her GLT (4 in the past year, 2 since Jan), I decided to try my hand at mounting/balancing tires.
(She claims "bad roads", and they *are* bad. I however drive on the same roads....and more than she does. Haven't killed a tire yet)
I picked up the manual tire changer and balancer from Harbor Freight, as well as the "duck head" upgrade and a couple other needed items (like bead jacks).
After a little trial and error, I figured out the system that also works pretty good with these low-profile "stiff" tires I like to use. Took me about 20 mins or so to dismount/mount the second tire over the weekend.
The new set went on the back of her car, as I don't need her bashing the NEW tires just yet. I have 2 other projects that I need to put tires on and a few junk tires I need to dismount and run to the recycler, so this stuff (I have about $300 into everything) will come in very handy and save me trips to the tire shop.
brunocerous
That looks great! Congrats!
What did you bolt the tire changer on to, a steel plate?
Chuck W
Post by Chuck W »
brunocerous wrote: 07 May 2026, 18:53 That looks great! Congrats!
It's a 1/2" thick AL plate. I tapped holes in it, so I could take things apart and store it away when I'm not using it...and the plate won't rust when it sits outside. It moves around a little bit, but now that I figured out the procedure, it doesn't require quite as much wrestling around with things.
I have the other half of that plate, and I could double-it up if I needed to, but I don't think that'll be necessary,
I don't have the garage space to put inserts in the floor and bolt it down there.
Been thanked: 4065 times
That cap pops off and leave you with this
New rear brakes for Evita 186k
Volvo rotors pads and ATE hardware.
Both calipers had a frozen piston which had torched one pad and rotor. Bad monkey
Used UBG Shagg calipers
Parking brake shoes were fine so I left them
Juno supported me by guarding the slate and listening for earthquakes
