I recently replaced the Blower motor on my S70. I tested the motor on the bench before install and it was strong. I did not replace the resistor. I am not 100% sure but I sort of feel like the fan is not blowing as hard as it should on high (slider all the way to the right). Now to be fair its 91 degrees with humidity in ohio right now, but i feel like it should be moving more air.
The fan speed increases and decreases upon command with the slide button as you would expect but i feel like i used to blow harder.
is it possible that the resistor is not opening up the fan to full speed? How would i test this possibility again if even possible.
99 S70 GLT - your opinion on blower/fan
- Grantkat
- Year and Model: 1999 s70 GLT
- Has thanked: 59 times
- Been thanked: 54 times
1999 S70 GLT ~193k
2014D VIDA/DICE
2007 Jeep Wrangler Unlimited ~ 315K
2008 Lincoln MKX ~130k
2008 Toyota Sequoia ~ 252k
Powered by coffee, stripped bolts, and questionable decisions.
2014D VIDA/DICE
Vova585
- Year and Model: 01v70xc,2016xc70...
- Has thanked: 228 times
- Been thanked: 238 times
Check the cabin air filter- replace if dirty.
"They used to make them better" can be said about many parts even if you replaced Behr oem unit with new Behr made in Turkey. So without knowing exact amperage consumed by "new old" unit and comparing it to your current one, it will be hard to tell. If you replaced high quality oem woth nissens, pro parts Sweden or other cheap aftermarket- be happy it is working and dont look further.
In most cases fan is changed with new resistor, but if money are tight, i understand risking a little and keeping old unit.
If you have the slider you have ECC which uses a transistor pack and modulation to control fan speed, not a resistor pack. Those don’t fail. I would check the cabin filter and also recirc mode which bypasses the filter
- Grantkat
ok will do....I tested it last night in the driveway and it was working super well.. I wonder if i just had a senior moment but i will keep an eye on it.
thanks
thanks
1999 S70 GLT ~193k
2014D VIDA/DICE
2014D VIDA/DICE
hausmeister
- Year and Model: 1995 850T5-R
- Has thanked: 276 times
- Been thanked: 84 times
I respectfully disagree, failed on my car a short time after I had to replace the failed fan. Mind, I did replace the fan as soon as I noticed it making issues, still probably killed the control box. But the fail was different, it only ran low speed, nothing more.abscate wrote: 19 May 2026, 22:50 Those don’t fail. I would check the cabin filter and also recirc mode which bypasses the filter
850 T5-R '95 auto
- jreed
- Has thanked: 384 times
- Been thanked: 221 times
There was a report from a while back (2012) that 11-15A is a typical range for current draw on a blower motor for 850 / S70 / V70:
viewtopic.php?t=46383
If you have a meter capable of measuring relatively high currents, you could check the current draw thru the motor and see if it's in range.
I might have caught the fan current in the bus current thread…stand byjreed wrote: 21 May 2026, 05:32 There was a report from a while back (2012) that 11-15A is a typical range for current draw on a blower motor for 850 / S70 / V70:
See here
viewtopic.php?p=670592&hilit=P80+house+current#p670592
hausmeister
Btw, I just found the part number form my order back then. If you are able to remove the motor from the blower cage, you can buy just the replacement motor: BOSCH 0 130 111 134
That is what I did on the 1995 850 back then.
850 T5-R '95 auto
- 4283 Views
Last post by Mikele82
- 16 Replies
- 3341 Views
Last post by CIK7
- 11 Replies
- 1958 Views
Last post by FLXC90
- 1589 Views
Last post by EuroDriver
- 31 Replies
- 5602 Views
Last post by VolvoOwl98
