99 S70 GLT - your opinion on blower/fan
Grantkat
Year and Model: 1999 s70 GLT
Has thanked: 59 times
Been thanked: 54 times
Post by Grantkat »
I recently replaced the Blower motor on my S70. I tested the motor on the bench before install and it was strong. I did not replace the resistor. I am not 100% sure but I sort of feel like the fan is not blowing as hard as it should on high (slider all the way to the right). Now to be fair its 91 degrees with humidity in ohio right now, but i feel like it should be moving more air.
The fan speed increases and decreases upon command with the slide button as you would expect but i feel like i used to blow harder.
is it possible that the resistor is not opening up the fan to full speed? How would i test this possibility again if even possible.
1999 S70 GLT ~193k
2014D VIDA/DICE
2007 Jeep Wrangler Unlimited ~ 315K
2008 Lincoln MKX ~130k
2008 Toyota Sequoia ~ 252k
Powered by coffee, stripped bolts, and questionable decisions.
Vova585
Year and Model: 01v70xc,2016xc70...
Has thanked: 228 times
Been thanked: 238 times
Post by Vova585 »
Check the cabin air filter- replace if dirty.
"They used to make them better" can be said about many parts even if you replaced Behr oem unit with new Behr made in Turkey. So without knowing exact amperage consumed by "new old" unit and comparing it to your current one, it will be hard to tell. If you replaced high quality oem woth nissens, pro parts Sweden or other cheap aftermarket- be happy it is working and dont look further.
In most cases fan is changed with new resistor, but if money are tight, i understand risking a little and keeping old unit.
Has thanked: 1609 times
Been thanked: 4064 times
If you have the slider you have ECC which uses a transistor pack and modulation to control fan speed, not a resistor pack. Those don’t fail. I would check the cabin filter and also recirc mode which bypasses the filter
Grantkat
Post by Grantkat »
ok will do....I tested it last night in the driveway and it was working super well.. I wonder if i just had a senior moment but i will keep an eye on it.
thanks
1999 S70 GLT ~193k
2014D VIDA/DICE
hausmeister
Year and Model: 1995 850T5-R
Has thanked: 275 times
Been thanked: 84 times
Post by hausmeister »
abscate wrote: 19 May 2026, 22:50 Those don’t fail. I would check the cabin filter and also recirc mode which bypasses the filter
I respectfully disagree, failed on my car a short time after I had to replace the failed fan. Mind, I did replace the fan as soon as I noticed it making issues, still probably killed the control box. But the fail was different, it only ran low speed, nothing more.
850 T5-R '95 auto Image
jreed
Has thanked: 384 times
Been thanked: 221 times
Post by jreed »
There was a report from a while back (2012) that 11-15A is a typical range for current draw on a blower motor for 850 / S70 / V70:
viewtopic.php?t=46383
If you have a meter capable of measuring relatively high currents, you could check the current draw thru the motor and see if it's in range.
jreed wrote: 21 May 2026, 05:32 There was a report from a while back (2012) that 11-15A is a typical range for current draw on a blower motor for 850 / S70 / V70:
I might have caught the fan current in the bus current thread…stand by
See here
viewtopic.php?p=670592&hilit=P80+house+current#p670592
hausmeister
Btw, I just found the part number form my order back then. If you are able to remove the motor from the blower cage, you can buy just the replacement motor: BOSCH 0 130 111 134
That is what I did on the 1995 850 back then.
