yes, thats it!
From pictures in that thread, zB, counter =100 is full heat, Counter =0 is full cold.
P80 C70 Hvac Drivers side only hot air, damper motor position, map of position counter, internal pictures
- Been thanked: 4063 times
- jreed
- Has thanked: 384 times
- Been thanked: 221 times
I had the same question when I was re-installing mine, and what I did was rotate the blend door almost all the way clockwise and I set the damper motor almost all the way clockwise using a 12V DC power supply (you can use a 9V battery instead).
CoupeC70
- Year and Model: C70 Coupe '01
- Has thanked: 10 times
- Been thanked: 2 times
@jreed
I think this is the best way
Can you tell me which side of the damper motor corresponds to the clockwise direction?
When I've opened it, should the small gear be at the top or the bottom?
- jreed
Yes, this is a good question and I really had to think it through when I was doing the reinstallation. I rotated the blend door clockwise as viewed from the footwell of the driver's side. Then I rotated the shaft of the damper motor clockwise as viewed from the back of the damper motor. Note that when you are looking at and facing the shaft on the damper motor directly, from that point of view you have to rotate the shaft counter-clockwise.
CoupeC70
@jreed
Ok Nice,
Okay, if it's lying open in front of me, then I have to turn it counter-clockwise.
Unfortunately, I don't know yet which direction it is.
Check my photo. I attached the gear by hand. The sliding contacts are now located where the red mark is.
Ok Nice,
- Screenshot_20260701_103143_Photos.jpg (35.86 KiB) Viewed 300 times
- jreed
Here's what my old damper motor looks like on the outside face with the shaft that contacts the damper. The blue arrow points to the most counter-clockwise position of the shaft. This is the position you would want to have the shaft if you are going to rotate the damper to the most clockwise position.
Damper motor outside: I took a photo of the gear on the inside too, after removing the damper motor cover.
Gear:
Gear:
CoupeC70
@jreed
Damn, this is the full end position ??
But the track is much longer than the end position. I thought the end of the track was also the maximum end position
Are these two black notch lines on the plastic cover an indicator for anything?
It looks as if they indicate the end positions of completely cold and completely warm
I thought that, too.
Maybe hook it up and run it carefully and check operation ?
Added more description to title , will add part numbers
- 13 Replies
- 4194 Views
Last post by BEJinFbk
- 9 Replies
- 4096 Views
Last post by jvl
- 16 Replies
- 397 Views
Last post by TisMe
- 976 Views
Last post by odaikorob
- 12 Replies
- 2072 Views
Last post by cbarbsnv70
