Just got the PO172 code. I was checking my vacuum lines and found a small crack in the elbow that connects to the passenger-side manifold. Is it possible to replace this elbow without removing the manifold?
I also want to clean the MAF sensor, but I don't have the wrench for the star bolt with the pin in the center. Does anyone know the proper name for this bolt and where I can buy the wrench?
Any other suggestions for removing the code would be greatly appreciated.
PO172 97 850 NA
- misha
- Has thanked: 155 times
- Been thanked: 432 times
It is possible but a lot of hassle,remove the plastic hose/housing which goes onto throttle plate and whole pcv end which goes on it.
Go from throttle plate side with little hard vacuum pipe behind intake manifold and first connect the rubber elbow onto nipple on intake manifold...then connect it to the pcv end.
About maf....remove the ribbed hose and whole Maf from air filter housing...spray Maf cleaner without touching the sensor...let it dry and re-install.
'71 144 S
'73 144 De Luxe
'78 244 DL
'78 244 DL
'79 244 GLE
'85 340 GLS
'71 144 S
'73 144 De Luxe
'78 244 DL
'78 244 DL
'79 244 GLE
'85 340 GLS
- Has thanked: 2856 times
- Been thanked: 1332 times
This one? 2nd pic viewtopic.php?p=233700#p233700
IIRC I took off the coolant hose. It's tight but do-able. I think I used long-nosed pliers. Ignore the lack of elbow, it's all the same whether it's elbow or flexible line as far as getting in there.
It’s a security Torx bit. You can buy them ftom Tekton tools in GRR , michiganjanuwan wrote: 02 Aug 2026, 11:04 Just got the PO172 code. I was checking my vacuum lines and found a small crack in the elbow that connects to the passenger-side manifold. Is it possible to replace this elbow without removing the manifold?
5 point Security torx, not a standard Security Torx...Storx? children coming?
- Has thanked: 2199 times
- Been thanked: 1851 times
I got the 5 point Torx security bits from Amazon. I bought 2 different packs, one T25 5 point and a 2nd with multiple sizes. Now they always go to the junkyard with me to pull MAF sensors if they are still there.
Security torx bits at Amazon, my affiliate link embedded.
- dalel
- Year and Model: 1998 V70
- Has thanked: 29 times
- Been thanked: 7 times
Did januwan get the info he needed? I do like matthew's solution.
I just did a PCV kit on my v70. I think its pretty much the same engine. I attached a picture to be sure. I looked at it again and it would be pretty tough getting the elbow into the wider hose that goes under the manifold. Probably if you had to... with a couple of long needle nose pliers. If I were januwan, I'd buy a manifold gasket and pull the sucker to fix the hose... Dale L
- pcv2mfld.jpg (31.4 KiB) Viewed 1087 times
Fine for the MAF bolts into plastic, but a security torx bit is a lot weaker than a standard torx bit fue to the “hole”scot850 wrote: 02 Aug 2026, 19:59 I got the 5 point Torx security bits from Amazon. I bought 2 different packs, one T25 5 point and a 2nd with multiple sizes. Now they always go to the junkyard with me to pull MAF sensors if they are still there.
I’m getting old, cranky, and allergic to cheap tools
- Has thanked: 311 times
- Been thanked: 817 times
Pay close attention to Neil's post: the MAF has a five point security Torx head, unlike generic Torx which is 6-point.
If you just buy a standard security Torx set you won't get a bit that fits.
You can also take it out by just clamping on a pointy vise grip, and/or tap it with a punch to get rotation started. But to clean the MAF leave the Torx alone, like misha says.
januwan
- Year and Model: 97 850 NA 209 K
- Has thanked: 7 times
- Been thanked: 3 times
Thank you for the feedback. I patched the crack in the elbow, but it did not fix the problem. I also found other issues. There is a lot of oil behind/below the manifold, and I failed the glove test. Next weekend I will be doing it for the third time. Second, because the kit I bought contained URO junk.
This time I may go with Matt's modification
And I made a stupid mistake ordering a security wrench with a 6-point star instead of a 5-point (pentagram).
Thanks again.
Thanks again.
januwan
- 1853 Views
Last post by hermechanic
- 2175 Views
Last post by Reys
- 4699 Views
Last post by tryingbe
- 667 Views
Last post by shaker_chi
- 871 Views
Last post by misha
