V70 turbo year 2006 209 hp
Chili58
Year and Model: 2003 XC70
Has thanked: 3 times
Been thanked: 12 times
Post by Chili58 »
Can anyone help with new ideas!
Car has B5254T2 motor, 2006 with turbo and 209 hp.
Its VVT sprocket area leaks oil. Oil can be seen coming behind the sprocket. I have replaced the axial seal between VVT-sprocket and the engine body - called front cam seal. I also have there a new VVT-sprocket having also a new green O-ring inside.
But no matter which depth I install the seal, I get oil leak from behind the VVT sprocket. I have Volvo tools +0, +1 mm and +2 mm, but no help.
The issue started when I installed the cylinder head after machinery works and replaced turbo.. (The cylinder 3 had issue which was caused by a loosen steel ball, which had got loose from a banjo bolt and entered into the intake manifold and from there into the nr 3 cylinder and finally through turbo to exhaust pipe.)
I have checked and learnt myself all about this issue, but no success to find the reason.
Today I started to think, if the cylinder head gasket is not correct and not suitable for this engine even...blocking oil flow.
dikidera
Year and Model: S60 2005
Has thanked: 68 times
Been thanked: 187 times
Post by dikidera »
These are unfixable. Same deal here, no matter what seal, how and where you put it, it always leak immediately.
Chili58
Post by Chili58 »
Well - it was OK beforehand. Now I used a RTV silicon sealant outside the cam seal. Lets' see tomorrow when it will be dry, how it works.
Nice advices here: viewtopic.php?t=100439
Been thanked: 504 times
Post by cn90 »
How many km on the odometer?
After some 200K km...the Exhaust VVT has so much wear that you need a new hub.
Chili58
Post by Chili58 »
Yes, it has 330.000 km. I measured exhaust: 3,2 mm and intake 1,7 mm.
I replaced both.
Has thanked: 2197 times
Been thanked: 1851 times
What brand of seals are you using? When I bought my 00 V70R it had supposedly had the engine seals done. Not long after buying it I had to pull the engine and replace all the crank and cam seals as they were leaking.
Since then, I only use Volvo or Corteco (OEM supplier) seals.
Is you seal fitted back to the same depth the original came out?
Chili58
Post by Chili58 »
Yeah, issue can be Victor Heinz seals, which I tried. Corteco could be more tight.
I tested different depth, but no difference. Used 3D printed, original design tools.
DavidE7
Year and Model: 01-07 V70, S60, XC70
Has thanked: 66 times
Been thanked: 92 times
Post by DavidE7 »
Did you verify the PCV system is clear and the glove test passes? The slight vacuum inside the engine from the PCV system helps keep oil from leaking out the cam seals.
David E
2001 Moondust V70 2.4 293,000 miles
2001 Nautic Blue V70 2.4 231,000 miles
2004 Nautic Blue XC70 2.5T 258,000 miles
new: 2004 Black Saphire V70R 193,000 miles
2007 Titanium S60 2.5T 277,000 miles
2007 Magic Blue S60 2.5T 233,000 miles
2007 Silver V70 2.4 203,000 miles
P2 Volvos for every person in my family
Chili58
Post by Chili58 »
Yes, I am very familiar with different Volvo breathing system. This has all new there and has irmal, small vacuum - all ok there.
